(SYD) Nissan 180sx 97 RPS13
Hey guys and girls, due to P platers restriction I have decided to sell my car. I would like this car gone just because it needs to be driven more than it should
Model: 1997 Nissan 180sx RPS13 Genuine Type X
Colour: White
Transmission Type: 5 speed manual
Rego: March 2012
Mileage:98,7XX Kms
Price: $9,500 Negotiable, willing to swap with a daily + cash my way
Contact: Call me on 0412 190 242 for serious offers and inspections
The only mods done to the car which was by the previous owner were:
- Cusco Front Strut Brace
- Apexi Muffler
- Saas Boost Gauge
- Pod Filter
- Chargespeed Front bar
- Uras Tail lights
- Tein Springs
- Unknown 16" Wheels in white with 60-70% tread
Flaws
- The Gearbox Syncro's 1st and 4th gear wont go into gear that easily and we're in need of replacing since purchase but i've been able to use the car as an A-B ( can help source out a gearbox at around $300 )
- Door trim has a 1cm hole due to tweeters being installed previously
- Boot only opens with key
- Power Mirrors don't work for some reason ?
Car is clear from revs :)
Other Information:
I've owned the vehicle for the past 2 months, purchased as it sits so I thought it'd be a great base project to start on but due to the fact of losing my license for 3 months I would love to keep it but i have to grab a non-turbo vehicle since after I get my license back I'd still be on my p's for another period of 6 months so 9 months till my fulls.
The car has only done 1000km's since purchase which averages on a range of 100km's per week.
As people that do know me I always keep my cars clean and well taken care of, I'm usually a very fussy owner and always likes to keep the car garaged. Only things that's needed to be seen as a genuine type X is the Front bar and tail lights and you have yourself a cheap late model type x.
I'm in no rush to sell the flaws of the vehicle i know will reflect on the price with offers coming in but please no low ballers, if the car doesn't sell at the price that i would like then it will garage it until I have my fulls.
Any offers are welcome, also wouldnt mind a non turbo daily + at least 3k my way.
Thanks for viewing,
Syd.
https://www.sau.com.au/forums/topic/374096-syd-nissan-180sx-97/
  • 3 weeks later...
  • 3 weeks later...
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
