1 piece split dump pipe (i believe its a jjr one) $150
post-27276-0-77103500-1313383632_thumb.jpg post-27276-0-78181600-1313383653_thumb.jpg
Blitz BOV, has an attachment (flange needs to be welded to the tube) to plumb it back if mounted in the factory position, DOSE NOT come with the adaptor to mount in the factory position $60
post-27276-0-92676600-1313383389_thumb.jpg post-27276-0-96208500-1313383417_thumb.jpg
6x factory gtr coils (Will also fit S1 R33 and R32), all worked well, i replaced them with yellow jackets when i put the 3540 on $120
post-27276-0-75948700-1313383503_thumb.jpg post-27276-0-69864300-1313383518_thumb.jpg
Crank angle sensor, bought it to try to fix a problem but the cas was not the problem $70
S1 igniter, once again bought to fix a problem, it wasnt the igniter either, i have 2 of these $90 each.
Standard front and rear struts with lowered rsr springs, no leaks worked well, replaced them with height adjustable coil overs when i got defected for too low (the only part of the car that was too low was a flange on the exhaust) $275
post-27276-0-94791400-1313383691_thumb.jpg post-27276-0-90965700-1313383707_thumb.jpg
S1 R33 grill with red S badge, replaced with GTR style grill but i didnt like the red badge so i swapped it for the factory chrome one, two clips missing of the back, just missing not broken, if this is to replace a damaged grill you could probably get a couple out of the one, how ever the center one is broken off, only ever had 3 or 4 of them on when it was on the car and was 100% secure without the middle one $30
post-27276-0-22794100-1313383447_thumb.jpg post-27276-0-82797200-1313383479_thumb.jpg
Factory gearbox speed sensor, came off a S1 R33 gtst no idea what other models it would fit, one again bought to fix a problem and that was not the problem $60
Battery box, no strap or brackets $30
S1 R33 indicators with built in driving/fog lights $40
post-27276-0-44095900-1313383302_thumb.jpg post-27276-0-13833300-1313383322_thumb.jpg
All prices are negotiable so throw me an offer, will also swap for an unmolested Mspec front bar and reo (happy to deal if you have either or both) for a S1 R33 gtst.
https://www.sau.com.au/forums/topic/374105-r33-parts/
how much you want for the front and rear shocks? Could you please sms me reply on 0404085915 thanks
Do you meen without the springs? if so im not willing to separate atm, price is up there for the lot or throw me an offer.
All pm's have been replied to.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5968262
Struts and Mspec lights sold, also have a HKS mushroom pod.
Comes as pictured, it did have a securing bracket but that seems to have gone missing, if i find it before it is sold i will include it other wise it does not come with it $60
post-27276-0-19229200-1313490990_thumb.jpg post-27276-0-15147200-1313491010_thumb.jpg
Everything else below is still available.
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5969955
Adding a S1 vented fibreglass bonnet:
Good condition, does not come with washer jets $200
post-27276-0-38573200-1313905951_thumb.jpg post-27276-0-73428000-1313906196_thumb.jpg
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5977235
Bonnet sold.
grill, hks pod and dump pipe sold pending payment.
Below is what is left.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5983285
Dump pipe, pod and grill back up for sale.
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5985994
CAS sold.
HKS mushroom pod, Comes as pictured, it did have a securing bracket but that seems to have gone missing, if i find it before it is sold i will include it other wise it does not come with it $60
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5986654
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
