Hey Guys. Got some gear for Sale. Sold my car.
1. HyperGear PU Turbo. Pretty much brand new. 500HP
Installed it in the car, which sat in the garage until I could save for injectors and a tune (sold the car before this happen). Probably did about 50 - 100kms with it installed driving from panel beaters/mechanics etc. Even then it didn't see boost since it wasn't tuned yet.
Can find detailed discussion and info on it here: HyperGear thread page 22
Paid $1200 for it. Probably take the First offer over $1000 gets it
An extra $80 for the braided oil line that goes to the top of the turbo (required). I need the standard "curly" oil line that goes to the top of the turbo. Can work something out if we can swap.
2. Apexi Steel Intake pipe. (Hardpipe)
Fitted up fine to my R33, Came off an R32. Guessing it should be fine on any RB20/25
Has the two inlets for breather etc. Used but in pretty good condition. Still shiny. Very Rare.
$120
3. Front Gaurds To suit R33. Silver But I would respray them. I'll let the pictured do the talking.
$80 Each
4. Nissan Z32 Air Flow Meter. Good Condition.
$150
5. Bosch 040 Fuel pump
$100
No longer Have an R33 but We have a Stagea. Interested in a front and Rear bar If anyone is interested in swaps. Otherwise $$$$ is fine
Contact me via text on 0433 117 369 for quickest response
Pics coming
Edited by LiQuid IcE
all items located in Endeavour Hills, Melbourne.
Intake Sold pending payment
Correction: Paid 1300 for the turbo
Cant edit original post. Also got...
6. Turbosmart Dual Stage Boost Controller
Comes with everything in the pics. Will also provide a new rocker switch which I believe makes it complete.
They Go for $260 New on ebay and I saw a 2nd hand SINGLE stage on ebay for $175
$180
Pipe was picked up this arvo by Steve. Nice car!
hey thanx. more attention then my g/f ;).. so wihh i came on 10 hours earlier.. so been after one of those apexi pipes, they also look sexy ;)
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
