1990 R32 GTR
132 812 km
Full bare metal respray in 350z titanium silver, outside, inside door jams, etc
460hp @ all 4 wheels on 20psi.
Engine
Forged CP Pistons
Forged Eagle Rods
Metal Head Gasket
N1 Oil Pump
N1 Water Pump
New Gaskets, Rings and Bearings and rocker cover washers on rebuild
Clear Timing Cover
Polished Intake Manifold
Rocker Covers repainted silver
Gates Hoses
Gates Timing Belt
1000cc Sard Injectors
Koyo Alloy Radiator
Custom Made Catch Tank and Braided Lines
Greddy T78 Turbo Kit (Manifold, Turbo, Gate, Lines, Dump )
Greddy Twin filter intake pipe
2 x Trust Airinx air filters
Trust Drag 115mm Intercooler kit
3.5" exhaust with 3.5" metalcat and HKS superdragger cannon.
Vipec Ecu with launch and boost control
ARC Radiator Diffuser
Sard Racing Fuel Pump
Driveline
Custom Triple Plate solid centre button clutch
Redline oil in diffs, gearbox and transfer
Solid Rear Diff mounts
Tein Coilovers and EDFC kit
Endless slotted Discs all round
Strut braces front and rear
PERFECT R34 GTR wheels all round, no gutter rash or damage of any kind. (with 80% Federal Super Steel 595 245/40 r18)
Interior
Seats, Door trims all retrimmed in standard colour scheme
Defi Boost, Oil Pressure and Fuel Pressure
Nismo 320 kph dash cluster
Switch for 2wd/4wd
Switch for low/high boost 16/20psi.
Nismo floor mats
Eclipse Head Unit
Focal Splits in front
Apline rear speakers
Immobiliser with central locking and alarm
Im sure i have forgotten something, but alot of money has been spent on this car and everything has been done right. I have receipts for around 60k worth of work, and that doesnt include the paintjob which was 12k. Serviced every 3000ks. Always garaged.
Selling due to not having time to drive it and appreciate such a fine piece of engineering.
Car will come with a RWC and 6 months rego.
Contact via text only pls as I am a shift worker and am very rarely on here.
Located Kallangur, QLD.
Mark
0424150944
Edited by sideways84
https://www.sau.com.au/forums/topic/374135-mint-r32-gtr/
+1 on asking Price.
Very very nice looking GTR :thumbsup:
A few quick Q's.
when was the engine rebuilt,
who by,
how many K's since rebuild,
Km's on Turbo
Re-Sprayed when
During the rebuild what crank/crank collar is used ie: Is it the origninal 32 crank?
Any sump work (baffle/extension)
Brakes - stock ?
https://www.sau.com.au/forums/topic/374135-mint-r32-gtr/#findComment-5967990
Sorry forgot the most important thing. 28k ono.
Rebuild, along with almost all the other work was done by Charlies Motors at East Brisbane. Engine was completed in 2007 and has approximately 16k on it since rebuild. Turbo was fitted at the same time. Not sure on details about crank or sump as the previous owner did all the work. Brakes are stock calipers with Endless slotted rotors with unknown pads, but does pull up very aggressively. Any other qs feel free to ask.
https://www.sau.com.au/forums/topic/374135-mint-r32-gtr/#findComment-5968185
  • 3 weeks later...
  • 2 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
