so i have brought a car and has a rb26dett power fc on a rb20 engine ower said its be wired to run it. so he was right as i have managed to get it running but pretty S**T tune
just wanting to know if anyone knows about this or has done this. iv tried looking for a 26dett ecu pin out to compare it to a 20det but i can find ever ecu pin out BUT A 26dett. im gathering the 26dett loom would run 2 maf sensor things hence 1 would have to be joined with the other or tricked to think its not there
just want to make sure its running ... alright b4 it goings to tune
The airflow meters are simply joined together so they read the same.
The GTR simply measures both, adds the values together and divides by 2.
WOrks fine with them linked, as I've done it many times with success.
If the car runs and starts, and all the sensors check out ok, then I wouldn't worry about touching it. Just get it tuned.
I think the injector 5 and 6 are swapped in the RB26 ecu plug vs the RB20 ecu plug. You can double check yourself it's been a long time since I looked at them.
http://www.s-chassis.com/resources/wiki/index.php/Skyline_ECU_Pinouts:_RB20,_RB25,_RB26
I'm pretty sure its actually injector 4 and 6 that are swapped.
I've got the diagrams somewhere, and the full inscructions on how to make the RB26 ECU work in the RB20. I'll have a look tonight.
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
