Hi All,
I have the following for sale:
*Apexi SAFC II blue screen model. $100
*Turbosmart Two stage electric boost controller. Solenoid controlled bleeder type. $50
*Nismo white duracon gearknob. As new,in box with selector sticker. $40
*Super pro rear arm bush set SPF1638K. $20
*2x KICS 20mm Bolt on wheel spacers 4/114.3 PCD 12x1.25mm pitch studs - suit nissan or honda $80
*2x KICS 25mm Bolt on wheel spacers 4/114.3 PCD 12x1.25mm pitchstuds - suit nissan or honda $80
*2x NAL 25mm Bolt on wheels spacers 4/114.3mm PCD 12x1.25mmm pitch studs -suit nissan or honda $80
*2x HKS Coilover springs - 201mm long,65mm ID,8kg/mm rate. New in box. $50
*2x HKS Coilover springs - 253mm long,65mm ID,7kg/mm rate. New in box. $50
*RB25DET pink label (R34/C34) air flow meter $100
*Mearcat Gauge pod -Single - suit S14 pillar mount. brand new. $50
*Mearcat Gauge pod - Double - suit C34 centre dash. $20
*Mearcat gauge pod - Single - suit C34 pillar mount. $20
*Blown R34 GTT std turbo. - Good for high flow rebuild. $100
*Defi control unit II $80
*Defi 60mm Amber Oil pressure $100
*Defi 60mm Amber Oil temp $100
*Nardi classic 3 spoke steering wheel - 340mm diameter. Includes horn button and centre ring. $200
*Trust Oil cooler kit - Suit S14. $250
Prices are firm.
Pickup from Parramatta/Northwest by arrangement.
Postage available for added cost.
Justin...
0418 663628
https://www.sau.com.au/forums/topic/374210-mixed-parts-for-sale-sydney/
20mm spacers are available again. Non-payment means non-delivery...
Items still available:
*R34/C34 RB25DET AFM $100
*Nismo Gearknob $40
*20mm 4/114.3mm PCD bolt on wheel spacers $80
*Nardi Classic 340mm dia. Steering wheel with horn button and centre ring,in black $200
*Mearcat Gauge pod -Single - suit S14 pillar mount. $50
Justin...
Edited by fergo308
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
