R32 GTS-4 rb25neo conversion.
Personal import 3rd aussie owner all jap paper work with service manual
Vertex body kit few marks on front bar, paint in very good condition
Gtr grill and bonnet
Rear spolier removed and holes filled in
Gmax 18x9 rims
Dba slotted rotors all round
Hicas lock bar with all lines removed
Whiteline sway bars front and rear
Koni adjustable shocks with king springs all round
Cusco adjustable caster rods
New Superpro adjustable upper control arm bushes
GTR gearbox with grex heavy duty clutch 10k old
working 4wd with on/off switch
Big fmic
Quality alloy radiator
GTR front and rear seats
Pioneer stereo with pioneer speakers and splits front amd rear
Tinted windows
R34 ecu with nistune,
r33 turbo
Walbro Fuel pump
Xforce 3 1/2 inch stainless steel exhaust with high flow cat
3 inch dump pipe
more photo's to come
much more, will not disapoint only down fall has rear diff whine
8,750 ono with rwc
car can be viewed in Hoppers Crossing or Gisborne area
Mobile 0408536600
cheers
https://www.sau.com.au/forums/topic/374235-r32-gts-4-rb25neo-manual/
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
