Well I just dont like em, however I wouldnt mind if it only worked with parker lights and not full beam. Would this be difficult to do? Also, will disconnecting the sensor disable the auto lights altogether? If only I had a wiring diagram....
https://www.sau.com.au/forums/topic/374237-automatic-headlights/
Put a relay on the sun sensor that gets its trigger from the parkers.
Parkers are the switch, sun sensor positive wire (whichever really) is the 12v and the output.
Ground is ground.
  On 16/08/2011 at 4:05 AM, bentwagon said:
Thats the easy solution taked care of, CHEERS! :thumbsup:
Now, anyone want to put their hands up for running the auto lights for parkers only??
You could disable the auto lights by not turning them on!!? And why would you want to run with parkers? In this country itis illegal to run on parkers only - i.e. if its dark enough to trigger your auto lights you need your headlights on.
I do a lot of country work and have the parkers on during the day and usually forget to turn them off - which is where the auto would be useful if i bypass the light sensor. What i hate is at night switching in the order of - OFF - AUTO - PARKER - FULL BEAM. This makes the full beam flash as i click through which makes people think im flashing the lights at them, especially the neibours across the road whos bedroom is opposite our driveway
If it's night time, why do you insist that you have to go past 'Auto'?? I think it works perfectly, all my imports have had 'Auto' mode going right back to my HR31 Coupe and Passage GT.
I just prefer not to use it, why can't it be after parker and low beam. Then there is the annoying lights on and off at dusk n dawn. Honestly I think I'm intelligent enough to know when to do things like use my headlights or windscreen wipes, I guess I'm old school where I prefer to drive the car and not have it do all the thinking for me.
Quick Qs, regarding M35s...
Seperate to the Auto Headlights.... Are the dash lights auto dimming too? Like all this week, with my headlights off, at around 5:30pm on way home from work, not dark but not bright sunny either, the aircon display and dash go dim...
Yep, the light sensor triggers the "night" level when I go under a bridge.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
