Alright!
Sprints are less than two weeks away! so get your rides ready!!
$110 entry free.
Another $107 if you don't already have a CAMS licence and $50 more if you're not in a car club already.
Come on down, it's going to be EPIC! I'll be there as well as about 25 other epic cars and you could be one of them!
If you're thinking about entering but you've got a few worries\questions, just post up here and one of us will set you straight, or if you're a little shy, send me a PM and I'll help you out. :)
Edited by zoidbergmerc
would have liked to go to that, but the legerwood hill climb is the day before. Is that the last baskerville day for the year?
What are the numbers normally like for the legerwood hill climb?? I am thinking of coming up for a run.
Hey Guys,
Here is a quote from the MCCT website about this weekend
Club Day @ Baskerville!! Enrty fee $110. Scrutineering begins at 8.30am & Drivers briefing at 9.45am. Level 2 CAMS Licence required (available on the day) Please ensure your car and YOU are track worthy with fire extinguisher, approved helmet, steel valve caps, extra bonnet tie down, ankle to wrist clothing, clear plastic over head lights etc.Burgers, sausages & drinks available on the day.
Trophies will be awarded for various categories
If you have any questions, send me a PM or post here and we'll help you out :)
Well that sucked.
Where was everyone? pretty sure It was me and another R32 GTR :(
So it turns out the track I was meant to be rallying on was buried under water, so dropped in to check it out the super sprints on my way home. Major lack of skylines, only got to see the r32 gtr run while I was there :(
Some awesome runs from other cars though, hot damn that supra is fast!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
