hey all, as stated, i found a set of rims that i want to buy, but would like to see how they fit on my car, im looking for 18x12 rims, with an et of 10-20, so i can see how much guard pulling and rolling i need.
so was wondering if there is anyone who has a rim i could try fit for some measurements? im located in hurstville, sydney if there is anyone around that area.
i have done a template and it seemed to fit decently, but i dont know how accurate my template was.
anyone out there, could you please let me know
cheers
Jean
https://www.sau.com.au/forums/topic/374300-would-like-to-try-fit-some-rims/
oh and by the way, i used to run 17x9+38 on the rear and 17x8 +38 on the front, now looking at 18x10 +10 on front and 18x12 +12 on rear.
on the rears, i had about 50mm space left in the guards, fronts i had 30mm left,
You'll probably take up two lanes with 12" +12 on the rear.........
Go out to your rear wheels with a roller and add 6.5cms to the outside of the rim. That's how far they should stick out if I've done this right
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
