Hey there,
My 96 Stagea 25x has developed a rhythmic whiny sound, Im pretty sure it began when I got the cambelt done at 102,000km
At first though it was only occasional and very faint so I just assumed it would go away as the cambelt settled in or something.
Anyway 10,000 km later and it is there pretty much all the time and is really starting to annoy me regardless whether it is doing damage or not!
Its only at idle, and happens in all gears, ie park neutral drive etc
As soon as some throttle is added though it disappears.
Have added video so please add your 2 cents.
Dropped by a mechanic but he basically said it sounds like its from within the cambelt casing but hard to tell without opening things up and doing some decent investigation.
So looking at few hundred just to get started.
So if anyone else has experienced this or has any tips/advice would be much appreicated.
Its completely stock and I might foot down on occasion but generally its fairly normal use, Im no racer or anything.
Cheers,
Tom
Edited by tomlwatson
https://www.sau.com.au/forums/topic/374322-stagea-rhythmic-noise/
Take you 5 minutes to remove the top cam cover - see if the belt is too tight or fraying etc. Mark the CAS so it goes back on in the exact same place and don't turn the engine at all while doing this.
OK its a 25X which is a non turbo, correct?
I have a 25g also N/A. The timing belt was done because the old one laminated because the tensioner pulley bearing seized. A day later the waterpump shaft broke and the fan had an orgasm under the bonnet. Not my fault. It fa***ked the radiator too.
None of these things happened when I did the new belt on the RS4. So maybe someone has stuffed up either the fitting of the belt or have overtensioned one of the aux belts. Since 1984 all my Nissans have had the squeaky belt syndrome.
Incidently are you Aus of offshore? I have never seen/heard of another N/A in Aus.
really does sound to me like you're chewing out your water pump
Yes Mike, from what we experienced that seems a definite. I think it is the "squealie syndrome" from which we suffer.
I never had a "squealie" until I got my first Sky in 1984.
I dont think it is the water pump per se, it is the over tensioning of the belt that buggers the system. Is it the ribbed belts that cause the problem.I can not recall a problem with any vehicle that had solid belts, that is since , a long time ago.
If the W/P bearing seizes and the shaft breaks, that is an under bonnet orgasm.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
