They are self cleaning, when the engine is shut off the sensor wire burns hot to get rid of oil and crap that has accumulated on it. Not a good idea to excessively clean them manually.
did you ask them to do it, or did they just do it for you and charged you for it? if the latter, might just be their way to get a few extra dollars out of you.
also, what filters are you running? if it's an oiled air filter then there might be too much oil in it and it's making them a bit oily.
I monitored the voltage from my AFMs they show around 900mv then drop to 500mv to 400mv while driving causing the car to stop suddenly before coming back to 900mv which is not at an optimal running level, but I am still able to drive the car around, The mechanics either did not check the millivoltage on my AFMs or did not clean them as I wanted in my original first visit to their garage, I did not want my AFMs to be cleaned a second time as I had to diagnose the problem my self and from the long list of things I have already replaced (Turbos, Fuel pump, Injectors, Coil packs, new air filters, Spark plugs) it wasn't hard (even for a amateur like myself) to link the symptoms (stalling, hesitating acceleration) to the AFMs and recognize they need to be replaced.
To have them cleaned a second time in such a short space of time when I said I was replacing them with brand new nismo units is not acceptable as I never asked for them to be cleaned “again” they just did it and then rang me to say they've cleaned my afms again and said theres no problem with the car....So if I didn't know any better I would believe/trust them drive away and later find out and be baffled when the car starts stalling and hesitating again....Thankfully I am an experienced mechanic..Not
Got some more info on AFMs,
damaged AFM may lead to increased fuel consumption and increased pollutant emissions as well as decreased power and throttle response (I was only getting 250km to a tank)
The engine may fail to ignite, causing misfire and a large increase in unburned hydrocarbon HC emissions
Lean mixtures burn hotter and may cause rough idle, Hard starting and stalling, And can damage the catalytic convertor (I had some of my cat come out while I was on lakeside raceway)
or burn valves in the engine
The risk of spark knock/engine knocking (detonation) is also increased when engine is under load
Forced induction engines can be catastrophically damaged by burning too lean for too long
The leaner the air/fuel mixture, the higher the combustion temperature is inside the cylinder
Too high a temperature will destroy an engine- melting pistons and valves
So if anyone is experiencing any or all of these things its your AFMs, I have also been told that if your AFMs need cleaning then they are already on their way out and should be replaced. Cleaning might might make it run better for a while but its going to play up again sooner or later. Its much safer just to replace it, a faulty AFM will destroy an engine quick smart
Edited by TommyR34
Whooah, slow down there.
Spraying the element with contact cleaner is hardly going to damage the element. If you are using an oiled filter that is over oiled then cleaning regularly is pretty simple insurance. If you are having ongoing issues with your AFM the most common reason is poor connections where they are soldered.
If you take the lid off the AFM and re-solder the connections (which is a 30-60 minute job for a noob) you can sort out the vast majority of AFM probs for not much effort. Certainly cheaper than spending $80-100 for a second hand one potentially with the same issues or >$300 on a new one.
I used a Power FC hand controller to monitor the airflow mv, let it idle for about 5minutes, went from 1200 1100mv when I first start the car, then after 5minutes dropped to 900mv and then was randomly dropping down to 500mv 400mv mark at which point almost stalling, Really does help to do research
The AFM has a voltage reading, can be seen by the PowerFC hand controller and no doubt Consult.
It's not the airflow reading you need to go off either.
It's the actual voltage. If it's stalling then the sensor for the AFM1 or AFM2 will actually show up as having failed.
I never clean my AFMs regularly. Once a year tops. Just use some degreaser and then heaps of water to wash it out.
Works fine.
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
