Wow, glad someone ran with this. Nice work!
After finding out I had my first baby on the way this fell by the wayside.
After a lot of measuring I was going to use the 10" front spring (275lb/5kg) while using the Bilstein sleeves but turned upside down (like on the USA Supra forums). The sleeves then hang down off the circlip. I was planning to use another circlip below the top one to centre the sleeves, so they don't flop about at all (although the Supra guys don't seem to worry about it).
The Bilstein sleeves are required to be cut to slip over, but they are cheap and quality.
For the rear I was going to use 10" and 4.5kg/mm (250lb).
I went the Tein s-tech mediums instead and they are pretty good actually, noticeably firmer than the Kings.
  • 3 months later...
Couple photos of the installed rears - just for the sake of completing the thread a little. You may want to mount the thread a little lower than shown. The shot with three dampers shows a stocker next to the one fitted with a sleeve.
Other shot is the bushes for the strut tops & the plates I had made that fit above the bump stop - I didnt use the ones ISC sent.
  • 4 weeks later...
djr81,
quick question mate regarding the ISC strut tops, got mine today, and had a mate spin up some bushes ages ago from your diamensions, 15x10x32. just looked at the tops, before I go bashing away, did you tap the factory ISC 12mm ID bushes out and put yours in? or did yours come 15MM ID and just slipped yours in? cheers mate
only got around to fitting the fronts ATM, but much better setup that standard tops, more travel - have yet to measure. very happy so far
I changed my spring rates again as I wasnt totally happy with what I had. Went up another 25lb in rate front & rear.
The setup is such a massive improvement over how it was with the Nissan tops it just isnt funny.
I think I got about 30mm extra shock travel front & rear although the rears werent critical.
good to hear.
I have got the rears fitted up now too. Yeah same have yet to measure BUT, i'd say ive gone from about 70mm or so in the front to atleast 100. same for me, gained in the rear but wasnt that big of a factor. still havent had a chance to take it for a run and wont for another month or 2 but def worth the $400 or so to do it.
  • 3 months later...
I'm doing the front struts for now. Parts are being collected. Currently have Tein S-tech (medium) springs. ~4.1kg/mm front, 4.4kg/mm rear. Going to keep the 4.4kg rear Tein S-tech spring in the rear.
Have the ISC strut tops. Getting sleeves and springs sent. I done quite a few calculations and I think I can squeeze in a 10" 275lb front spring.
  • 5 weeks later...
OK so I finally completed the fronts on my R33 GTST. It was VERY easy to do once I had all the parts. I converted the original SK Bilstein shocks to coilovers with 5kg/mm springs.
Parts:
2 x Front strut tops to suit 2.5" spring (I used ISC R33 rubber mount strut tops)
2 x sleeves to suit bilstein shock (I used A1 racing, pn A1-12451)
2 x 2.5" lower perch to suit sleeves (I used A1 racing, pn A1-12460)
2 x 2.5" ID, 10" length springs 275 lb/inch (I used Hypercoils for $60 each)
2 x 10mm ID hardened steel washers (thick). One for under the strut top, one for on top of the strut top.
I got the sleeves, perch and springs from the USA and they shipped in a large flat rate US postal box ($60). I would have liked to go local but not for 220% of the cost.
Install:
You simply remove the strut top, take out the spring and perch and clean the shock body. Then place the circlip on the BOTTOM GROOVE. The slide on the sleeve with the internal square edge lip facing down. See the inner ridge in the pic.
This positions the sleeve very nicely about 3mm above the brake line bracket - pink circle. post-23086-0-09433100-1344570723_thumb.jpg
This shows the sleeve and bottom perch before sliding over the circlip.
Then you put the strut top on and assemble. The bottom perch is positioned 11 turns up from the bottom (counting the top of the ridges on the sleeve). This gives a wheel to guard height of 345mm (recommended).
Installed on the car.
NOTE:
1. The strut tops from ISC have an inner diameter of 12mm as noted in previous posts. The bilstein is 10mm diameter. You will need to find a suitable reducer for this to mount properly.
2. Bump stops - I previously had a combo of 1 x superpro bush and cut-down SK/pedders bump stop. Since the ISC strut tops add another 30mm of bump travel (and reduce droop by the same amount) I added another polybush to space down the bump stops. This poly bush was ~20mm long which is what I wanted (I wanted to add another 10mm to the travel before hitting the bump stops as the previous ones were a bit too quick to touch). You might be able to see the 2 x poly bushes and the old foam bump stop in this pic. It worked well for me previously and adding a 2nd poly bush like that should help make them even more compliant. This gives me ~40mm of bump travel before the shock touches the foam bump stop at 345mm height.
This is them installed, you can see the old foam bump stop just slides around. You can also see the 1 x hardened steel washer (10mm ID) that I put under the washer supplied by ISC (12 mm ID), there is also another on-top of the strut top below the nylon lock-nut.
Ride/Feel:
With the 5kg/mm springs and ISC strut tops the ride is amazingly compliant. It doesn't feel any harsher than the 4.1kg/mm Tein springs I took out. However the front is definitely firmer when cornering and the balance of the car has shifted more towards neutral from oversteer.
Ride Height:
At 345mm height the spring is pre-compressed ~15mm at rest, then further compressed 60mm with the weight of the car. This gives 60mm droop travel for this combo, stock is ~80mm droop (limited by suspension arm movement - as the shock goes 90mm). Therefore with a 10" 275lb spring you could go down to 335mm ride height and have ~5mm pre-compression so the spring is trapped. Alternatively you go all the way up to and over stock ride height as the sleeves have plenty of thread left.
Edited by simpletool
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
