hey guys, another exhaust thread..
I got a quote of 190 fitted for a 2.5" cat back system for my 33....
The thing is the guy told me they make it up there as you can't get system to just 'bolt-on'...is this BS?
Recomend me a moderetly priced system...mainly need it to sound sweet as stocko one sounds stupid :(
https://www.sau.com.au/forums/topic/37441-exhaust-yes-another-one/
well the stocko one sounds like gas hissing out of the tail pipes so its not much of a noise. There are Cat back systems, however the exhaust shop u went to probably don't get aany in as most are made in Japan. 190 for a catback is fairly cheap man, they will most likely be fitting a mass manufactured muffler such as a lukey or redback and just mild steel piping which probably won't be mandrel bend. If i were you i would do abit more shopping beofer getting one fitted. I had a lukey on my NA, cost $280, top of the linelukey muffler tho, and mandrel bent piping.
Clint
Clint
well in comparsion a 3" exhaust for a turbo charegd model is about $900 fitted
thats with 5" muffler or 4", size of muffler doesnt affect price. thats stanless steel and mandrel bent pipes from the turbo back
there are two type of bending from my knowledge. If I'm wrong about the following please feel free to correct:
Press bent - can be done by any exhaust shop. Causes pipe to become smaller in diameter where the bends are i.e --> ) (. Causes restriction in flow where the bends are.
Mandrel bent - requires more sophisticated bending machines. Pipe stays same diameter where the bends are i.e --> | |. Flow stays the same throughout the pipe.
HKS34R yeah ur descriptions are precise. Mandrel bending machines stretch the pipe pretty much to create a bend that is same diameter all the way through. Im pretty sure i had a Lukey Turbo Muffler which isn't straight through but flow's really well and just sounded great.
Clint
Remember you get what you pay for.
$190 is bugger all for an exhaust. You will probably get those nasty redback resonators that have protruding lumps that create a huge amount of backpressure/turbulence.
Ensure the mufflers/resonators they are fitting to the car have a smooth clean inside.. Hence the punched holes don't mave any material protruding in to where the exhaust gas flows.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
