Item Summary: Holden Statesman VS Series 2 Supercharged
Condition:
Fair condition for its age, don't expect it to be show-car worthy.
Reason for Selling:
I had plans to keep it longer, slam it more and fit 20" rims however I'm looking to get back into another jap car, so hence require funds.
Asking Price:
$3300
Delivery Methods: To be organised with buyer
Contact Info: Serious buyers please only contact me. I work 7 days a week and without sounding too arrogant I don't have time to spare for time wasters. Please call or txt me on on 0401233113.
Extra Information:
1996 Statesman VS Series 2 Supercharged
- 3.8l V6 Factory L67 Supercharged motor
- Eaton M90 Supercharger fitted with 3.3" (84mm) Universal Pulley, currently running 11psi while still retaining the stock/factory ECU.
- 2.5" press bent exhaust with twin hi flow catalytic converters fitted
- M30 four-speed 4L60-E automatic gearbox
- 176,000k's
- Factory 35% Tinted windows
- Factory Velour interior (no rips or tears on any of the seats)
- Factory Woodgrain Dash
- All power options working including power steering, power mirrors, cruise control, power windows and climate control.
- Pedders springs fitted in the front
- King Spring SSSL springs fitted in the rear
- Monroe GT gas shocks fitted front and rear
- Genuine OEM VT Clear side indicators fitted
- BRAND NEW Bendix General CT DB1085 front brake pads (Purchased & fitted on 18th May 2012)
- BRAND NEW Bendix General CT DB1086 rear brake pads (Purchased & fitted on 23rd May 2012)
- BRAND NEW NGK Spark plugs (Purchased & fitted on 23rd May 2012)
- Replaced faulty factory coil packs with new AC Delco set (Purchased & fitted on 22nd May 2012)
- Air Conditioning/ Climate control
- New Goodyear 215/60/R16 tyres fitted on the front (on 25th February 2011)
- New Kumho 215/60/R16 tyres fitted on the rear (on 12th August 2011)
MAJOR SERVICED RECENTLY CARRIED OUT ON THE VEHICLE (8/8/11 - 10/8/11) BY ULTRATUNE Parramatta
- New Engine Coolant Temperature sensor fitted
- New Water Temperature Switch fitted
- BRAND NEW Genuine OEM Radiator fitted, block was flushed and filled with 10L of Nulon coolant
- New Intake Gasket Kit fitted
- New Thermostat fitted
- New Thermostat Gasket fitted
- New Dayco Heater Valve fitted
- New Waterpump fitted
- BRAND NEW Genuine OEM LIM (Lower Inlet Manifold) fitted, (purchasing directly from Holden for $700 alone! was unable to source a used one from any wreckers in Sydney)
Have receipts totalling $1500 alone in parts from the Major Service just completed.
- NSW rego till 25th February 2012
- Clear Revs title with No Encumberance on the car (can provide further proof upon request)
- Some spare parts will be included in the sale, including factory springs, factory mudflaps, factory statesman grill & factory orange side indicators
Please note, Caprice chrome grill pictured fitted on the car will not be provided, instead the standard slotted Statesman grill will be fitted instead.
Pics:
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
