I bought a genuine garrett gt3582r yesterday, .82 rear, 4 bolt. I also ordered a 6boost manifold and 50mm wastegate which will arrive in 4 weeks from today. My car currently has; Z32 afm, 910cc at 3 bar JECS injectors, walbro 341 fuel pump, power fc, tuning crap, hd clutch, 3 inch front pipe, stock cat, 3 inch kakemoto catback. I have the car really well tuned currently on the stock turbo at 14psi. No knock anywhere and nice afr's. So I'm just after advice on putting this setup together. I can assemble it now worries. More just after tips for tuning ie: more timing and less fuel down low to fill up the lag gap? And ideas about afm placement? I have read a bunch of stuff about afm placement and am leaning towards leaving it in the stock configuration. I'm getting some oil and water lines from ebay. Are these as simple as bolting in? I read something about a 20 micron oil filter for the turbo. Anyway any info/ideas would be good.
:cheers:
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/
  • Replies 139
The exhaust will have to stay the same for now as I have already made the missus mad with my spending. Swapping the cat is on the cards. The exhaust will get replaced next year when the motor gets changed. Ebay lines are crap aye? Where's a better place to get them? I know a guy who works for enzed. I spose he could do it.
EDIT The engine internals are going to stay stock for 12 months so it wont be wound up too much. :whistling:
Edited by Room42
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5971905
I am assuming the turbo intake is 4", if so I wouldnt put a 3" afm in the intake, too restrictive on that sort of turbo. Yeah as said above exhaust will be restrictive, both cat and catback.
hardly, leave it in the standard position, make sure your intake pipe has a bend in it and you'll never have any troubles.
as for tuning, same basic principles apply as with a standard turbo, you want a gradual dip from cruising afr's down to 11.5-12:1 at peak torque/full boost then 12:1 to redline and as much timing you can run without inducing knock or going past MBT
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5972217
Kando dynamic do quality line kits for about $100. I would NOT call them ebay crap. Have used them myself in the past.
As for your setup, aslong as you have a decent gate (tial mvr or similar) and you replace that cat, you will be cool. A decent 3" cat is only $189, why skimp?
Also you did not mention an FMIC, make sure you have one of these too.
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5972301
045how lol I still have the 2 stock turbos and the t3 flanges arrived yesterday. I still dont have the head flange yet. Seeing as the rb30 in my shed is getting stroked next year I was thinking about keeping the flanges and putting another gt35 on it. We'll see. Jonnohr31 The missus is getting to be a good co-tuner so it should only take a good weekend to get the tune 90 percent. R31nismoid I'll go see the guy this arvy and let him know what I need. Only 3 weeks and 6 days to go. I already told the boss that I'm taking a sicky to put my car together :laugh::sick:
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5972311
I'll have a sus of the line kits today. I'm getting a turbosmart 50mm gate, its coming with the manifold from Kyle. Lol the cat will get replaced. I have a 600X300X100 front mount. Sometimes I forget the some of the stuff I have put on the car :wacko:
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5974222
The actual hole in the intake of the turbo is only around 2.5 inches. Its just the outside fitting that is 4 inches. Also you say cat and catback need replacing. Yes the cat will be too small. However it is more important to have a larger section of pipe at the start of the exhaust rather than at the back. If I were to replace the exhaust in sections I would start from the front and work back. Eg: Disregarding the cat (cos its getting replaced), I'd replace my 3 inch front pipe first.
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5974381
Everything in that setup is too restrictive for the potential of that turbo.
Its even too restrictive for a GT30R.
Not everything. The injectors flow 910 cc at stock pressure and 990cc at 4 bar. The afm is good for 360 kw or so. The intercooler is well big enough. I thinking about the future. I have an rb30 in the shed that I have almost ready to put with the 25 head and the missus and I have decided to get the spool 3.4 stroker kit next year. I have all the necessary bits on the car to make a stack more power except the turbo. Its better that I run this turbo near the low end of the efficiency range for now than flog the crap out of a smaller turbo that will get replaced in 12 months. Hey, I can afford to do up the car but I dont own a bank :whistling:
https://www.sau.com.au/forums/topic/374412-new-turbo-setup/#findComment-5974415
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
