  • 3 weeks later...
f**k yeah finally the laurel has rego again!
vg30 turbo is runnin well at 14psi.
originally had the boost controller in backwards haha watched it spike to about 25psi haha.
and got a wheel alignment this mornin.
gone from -5.3 degrees on the rear to -3.5 degrees. and -2 on the front. drives alot nicer now.
really need to give the rear gaurds a slight flaring tho. haha
pics of the new exhaust
vid of said exhaust.
just coz
  • 3 weeks later...
Nice Laurel mate..I've seen it at city dismantlers before??
I'm after some parts for mine (stock bumpers, corner lamps etc) if you can help that would be great just txt me 0400422460
Regards
Tom Monkhouse
cheers Tom.
yeah I used to work at AP Panel house in the city dismantlers complex but now im just bein a bum whilst trying to find a new job. haha.
Ive texted you regaurding the parts your after as i dunno how often you check on here,
ive got a lh corner light and a front bar but the front bar has been hacked up fairly well from the previous owners.
cheers
Danny
ok so im most likely goin to sell the eurolines to fund a set of wheels that fit better
thinkin these
in 17x8.5+30 and 17x9+30
rears will basically perfect fronts will sit in a bit but i have no issues with runnin spacers.
what does everyone think?
  • 3 weeks later...
top ones? as in the silver enkei?
thats pretty much what ive decided on haha. but possibly 9+30 for the rear. gonna test fit some wheels clost to them specs soon and see how they sit.
also shimmed up the diff tonight.
1 x 1.4mm shim, instant locker.... wasnt plannin on it bein a locker but ohwell haha
least it wont single spin like it was haha
oh lol.
yeah id like meisters..
but findin a decent set (ie thatll fit without touchin my gaurds) isnt gonna be easy i assume.
its a long way off yet either way. need to sell the eurolines before i make any serious moves to get new wheels.
  • 1 month later...
ok so eurolines are sold.
now back to the search for wheels haha.
found a set of panasports in 8/9 +20 and +30ish.
for aout 600...
but yeah gonna keep lookin to see if anythin cool comes up.
wouldnt mine a set of meisters/professors.
still avnt gotten the recaros in yet haha.
probs just gonna buy some new rails i think instead of waiting to have my current recaro rails modified.
also still having issues with the laurel having a hesitation between 1500-3500 rpm.
ive bypassed the knock sensors and its still happening. currently lookin for an r32 rb20 ecu so i can have it nistuned and see wtf is happening.
anyone know of one laying around?
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
