Mine does. Its just havin a rest. Haha
After this next few weeks itll get rego. Assumin it services stadium drift. Will hopefully see rego around middle of april. Assumin the money is there spare after payin for round 2 of stadium drift which is in may I believe. But there will be many pics and vids in the comin weeks.
so stadium drift was amazing!
entered street class with 5 other cars. most of them looked like track hacks not street cars but was still good fun, and i learnt a shit load.
friday practive was a bit dodgy with the weather track went from wet to dry a few times throughout the day, so was weird gettin used to the changin conditions.
saturday was perfect weather. sun was out, not to hot not to cold.
laurel performed beautifully all weekend right up untill the free expression session where the rack finally f**ked out.
i believe its worn the teeth out as the steering wheel moves a long way with the wheels not doin a hole heap. and i have more lock turnin right then left.
engine also decided it prefers its oil on the out side as it pumped about 4 litres of oil through the rocker cover breather.
and its been low on compression for a while now.
so i will be rebuilding the 20 and finding a new rack in the near future.
all in all i spent a shit load of money, melted a few pairs of tires, broke some stuff and have a freaking awesome weekend.
pics as promised. will post more as the photographers put more up.
601483_10151321333866487_1335652362_n.jp
598691_10200885153751050_1817081702_n.jp
there is a video on facebook that ill upload when i figure out how to save it from facebook haha
  • 3 weeks later...
well the engines coming out this weekend.
will be gettin stripped down and then parts will be ordered as needed on advice from the engine builder.
im tryin to decide if i should spend the money on gettin bigger cams. i keep hear very mixed reports on them.
opinions?
Yep I decided last night whats the point.
25 will make the same figures I want easier and with less money spent.
Now to find a 25 locally.
And work out how to make it run.
Anyone got a link to the wiring that needs to be done for this?
Engine found!
Picking up a series 2 rb25 engine package.
Less then 70k on the engine. Still in a running r33 which is auto and the most stock 33 ive ever seen.
Hopefully picking it up next week.
Runs amazingly. Never seen an rb idle so smoothly. No smoke. Revs smoothly. No noises.
Time to start pullin the 20 out.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
