soooo massive update.
lots has happened over the last couple weeks.
rb20 came out nice and easy.
victory smoke and cider
taking the rb20 for its last ride :(
rust was found..... lots of rust...
thankfully only surface rust.
rust was removed.
via drill and wire wheel. (shit idea. takes to long)
that was three hours worth of wire wheeling.
then via $59 super cheap auto sand blaster. (amazing! best $59 ive ever spent)
random selfie in my protective clothing..... lol
the aftermath... looks like its been sitting through an egyptian freaking sand storm haha.
painted in anti rust primer
painted in anti rust black paint
engine was delivered to me tuesday last week.
rad coz saved me driving an hour to pick it up and organising a trailer. haha
lots of part have been bought. with a few more to be purchased over the next few days.
list so far
asi silicone hose kit
new timing belt
water pump
engine mounts
rear main seal
gktech lock spacers
nolathane rack mounts
alloy gktech steering shaft bush
summit racing rpm window switch (to allow vct to work)
tonight luke and myself stripped the bits off the 20 that i wanted to keep.
and started stripping the 25 of the bits that im throwing away or replacing.
will hopefully have the engine in and running by the weekend.
need to get dr bolt out to remove the snapped exhaust studs.
Got the gearbox in tonight.
Still tryin to get my head around the wiring.
Cant work out how the rb20 uses a seperate loom for the starter and alternator
Where as the series 2 25 has them incorporated into the engine harness.
Well its finally running.
Still got a few little things to do like tail shaft and rack boots.
And tidy the wiring up.
But it starts and runs beautifully.
It seems the powersteering pump has died how ever.
Its makin a god awful noise and then sounded like it ground to a halt and blew a bunch of smoke.
So will need a new one.
And a speedo cable as its broken somewhere I believe.
32 should be the same yes?
soooo.
my power steering wont work..
ive replaced the hicas rack with a cefiro rack, its only got 5 ports.
since removing my hicas i only have 4 pipes. ive fitted them all. how ever there is one that is open and leaks fluid out of it..
other problem is when car is running it has no power assist.
anyone know what the other port is for. and how to make my steering work?
for reference its the far left port on the front of the pinion housing. its a bigger fitting then the one for the pipe that comes from the pump.
need this fixed tonight else im walkin to work...
ok so got the power steering fixed.
cefiro high pressure line was used, turns out laurel and cefiro even though both hicas. use different lines.
i made it fit though so all good.
serviced the engine on saturday and whilst i was letting the engine warm up so the radiator flush could do its job i noticed that it had split a hose under the plenum...
not happy at all... so thats gotta be changed.
took it for a drive up the street (had to move cars in the front yard anyway)
rack feels good, engines nice and responsive.
but the rear ends still floating all over the place. id assumed it was the rack moving around. but since the entire front end is now brand new. its gotta be somethin in the rear.
gonna jack it up in a bit and have a look. thinkin maybe cradle mounts. as ive changed the cradle. maybe they have come loose?
ive got alloy lock collars in there atm.
apon inspection, i found the cradle mounts are fine. and tight as hell.
i did how ever notice that my left hand traction arm one of the lock nuts has come loose
the right and toe arm also had a loose lock nut.
and also where both the toe arms mount to the cradle, theres visible signs of them having slipped in the cradle. odd considering that its not running the eccentric bolt and washer that holds them in from factory. ive replaced those with the gk tech lock out washers. but the bolts there were loose also.
have tightened them all up now and readjusted my traction and toe arms. just havent had a chance to test it yet.
hopefully thats fixed the issue.
  • 3 weeks later...
so i was getting all excited to register the laure yesturday, was up early working on it. in the freezing cold.
doing the last little bits of wiring, fixing the power steering resi from leaking. and swappin speedo cables out.
started it up. let it idle and get warm. then took it for a boot up the road and back.
revs hard. comes on boost hard. and just wants to bake tires. :)
as i pulled it back into the driveway, noticed there was a lot of smoke coming from the engine bay. popped the bonnet
and it was comin from exhaust side, so i kinda just assumed it was gasket goo, degreaser or spilt oil.
apon further inspection, turns out the exhaust cam cover is pissing out oil onto the exhaust manifold..
so thats a big dampner it. now i gotta pull the bloody cam covers off again. haha ohwells. good thing i hadnt registered it yet.
so changed the cam cover gaskets tonight. and took it for a boot round the block.
love it! so freaking happy :D
its registered, and assumin it starts in the mornin (suspect the battery is dead/dying) itll be gettin driven to work and some fresh fuel put in it.
its currently i little shitty under load when it gets up in the revs, which im assumin is either fuel or the fact the vct isnt connected running off an rb20 ecu thats not tuned.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
