well friday was a little dissapointing.
ran into a few issues on the dyno.
vct controller was turning on and registered rpm, but it wasnt actually doing anything. next problem was that the tps wasnt getting a signal either. apparently these two problems are linked. the way the 25 has been wired, i apparently missed the part that said i needed to power a wire from the ecu that gives power to the vct solenoid and tps. so i will be fixing that during the week.
next problem and a bigger one is that the bee*r rev limiter isnt letting the engine rev past 6000rpm.
unfortunately they ran outta time to disconnect the bee*r and fix the vct/tps and so the tune has only been partly done, and will require a little touch up once these things have been fixed.
having said that, it made 201.9rwkw on 14.5psi limited to 6krpm.
  • 4 weeks later...
and we have game over....
finally decided to do a compression test on the 25 to see if it would tell me why the cars a pig to start cold, random idles on 5 cylinders (but will rev and drive on 6) and why from time to time itll just blow a massive cloud of blue smoke as i pull up to a set of lights/stop (never does it driving or under boost).
so compression test results returned this
cold
80
80
110
120
80
120
warm
140
120
145
145
100
135
i wasnt to worried till i got to number 5 on the warm test.
put a little oil in the bore to see if itd bring compression up a bit but it still only read 100psi.
so im assuming rings are real happy in general but somethin else. maybe head gasket/head is the cause of the low readings on 2 and especially 5.
  • 1 month later...
have neglected this thread as much as the laurel lately.
after the comp test i got a leak down test done on it.
which confirmed the valves are f**ked in number 5. 75% leak trough the exhaust valves.
ive since sold my statesman and bought an r31 as a daily.
so the money from the statesman is gettin dumped on the laurel.
have bought a recon head for it. and this weekend ill hopefully find the motivation to pull the engine out.
then its time to pull it down. measure up and buy parts.
will be gettin forged pistons and new bearings and as i got the recon head for half the price of havin mine done ill likely slap some pon cams in it also.
Well I just bought a new engine. Picking it up next week.
Recon head. New bearings. Waterpump. Timing belt.
Which means ill have a series 2 rb25 long block for sale with a spare recon head. Paid $600for the head on sunday... found the full motor yesturday. Always the way. Haha
Picking up new engine on thursday night.
Picking up some 850cc denso injectors tonight. And have got a tomei fpr and top feed rail ordered from fleabay.
Gonna run it on e85 this time.
Just need to get manifold gaskets and studs. And then start swinging them spanners again. Eta 2 weeks.
Its goin to be very mildly tuned to start with. Goin from 180rwkw rb20. Ill be more then happy with a measly 220rwkw for now. Need to try and prolong the life of the rb20 box till I can afford an rb25 box and tail shaft
engine came out on thursday night.
stripped down the block friday night.
spent saturday morning fitting the exhaust side to the new block, then attempted to fit my top feed injectors and fuel rail to my inlet manifold.....
....thats where everything went to shit.
the rail doesnt fit. at all.
was going to make up some brackets to make it fit, but then I found a greddy copy front facing plenum on gumtree for $200 so grabbed that today.
I know they aren't the best things in the world, but this ones been cleaned up and faced so should be all sweet.
haha yeah as far i was aware they were all made to fit stock manifold....
but thats right. will look sexy and lets face it, the stock manifold and piping isnt exactly the nicest thing to look at.
as for the loss in midrange, im sure i wont even notice it. coming from a 20. everything gonna feel torquey as hell haha.
and for a "freddy" manifold it looks pretty good, to be honest.
Lucky I wish mine was raw. Check all your threads aswell before you go bolting it on. Mine had a few dodgy threads which I just ran a tap through. Will be a pain to get to some when its on. And if you have access to one, die grind the water jackets out a bit bigger, to match your gasket, same with your ports. I through my gasket on mine and got a paint pen to mark out the overlap and just ground it out and smoothed it so it matched the ports. Wasnt much to come off but may aswell.
so manifold is on,
bypassed the heater as the core leaks and the oil warmer.
next problem. is that my injectors dont fit my rail because its so badly made that the ports the injectors fit into are different depths ranging from 8.4m to 11.9mm.
so gotta get another rail,
and i have to do somethin about the dowel thats in my crank. for some reason my flywheel doesn't have the hole to accept said dowel..
anyways. no one really reads this crap, so here's some pictures
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
