well friday was a little dissapointing.
ran into a few issues on the dyno.
vct controller was turning on and registered rpm, but it wasnt actually doing anything. next problem was that the tps wasnt getting a signal either. apparently these two problems are linked. the way the 25 has been wired, i apparently missed the part that said i needed to power a wire from the ecu that gives power to the vct solenoid and tps. so i will be fixing that during the week.
next problem and a bigger one is that the bee*r rev limiter isnt letting the engine rev past 6000rpm.
unfortunately they ran outta time to disconnect the bee*r and fix the vct/tps and so the tune has only been partly done, and will require a little touch up once these things have been fixed.
having said that, it made 201.9rwkw on 14.5psi limited to 6krpm.
  • 4 weeks later...
and we have game over....
finally decided to do a compression test on the 25 to see if it would tell me why the cars a pig to start cold, random idles on 5 cylinders (but will rev and drive on 6) and why from time to time itll just blow a massive cloud of blue smoke as i pull up to a set of lights/stop (never does it driving or under boost).
so compression test results returned this
cold
80
80
110
120
80
120
warm
140
120
145
145
100
135
i wasnt to worried till i got to number 5 on the warm test.
put a little oil in the bore to see if itd bring compression up a bit but it still only read 100psi.
so im assuming rings are real happy in general but somethin else. maybe head gasket/head is the cause of the low readings on 2 and especially 5.
  • 1 month later...
have neglected this thread as much as the laurel lately.
after the comp test i got a leak down test done on it.
which confirmed the valves are f**ked in number 5. 75% leak trough the exhaust valves.
ive since sold my statesman and bought an r31 as a daily.
so the money from the statesman is gettin dumped on the laurel.
have bought a recon head for it. and this weekend ill hopefully find the motivation to pull the engine out.
then its time to pull it down. measure up and buy parts.
will be gettin forged pistons and new bearings and as i got the recon head for half the price of havin mine done ill likely slap some pon cams in it also.
Well I just bought a new engine. Picking it up next week.
Recon head. New bearings. Waterpump. Timing belt.
Which means ill have a series 2 rb25 long block for sale with a spare recon head. Paid $600for the head on sunday... found the full motor yesturday. Always the way. Haha
Picking up new engine on thursday night.
Picking up some 850cc denso injectors tonight. And have got a tomei fpr and top feed rail ordered from fleabay.
Gonna run it on e85 this time.
Just need to get manifold gaskets and studs. And then start swinging them spanners again. Eta 2 weeks.
Its goin to be very mildly tuned to start with. Goin from 180rwkw rb20. Ill be more then happy with a measly 220rwkw for now. Need to try and prolong the life of the rb20 box till I can afford an rb25 box and tail shaft
engine came out on thursday night.
stripped down the block friday night.
spent saturday morning fitting the exhaust side to the new block, then attempted to fit my top feed injectors and fuel rail to my inlet manifold.....
....thats where everything went to shit.
the rail doesnt fit. at all.
was going to make up some brackets to make it fit, but then I found a greddy copy front facing plenum on gumtree for $200 so grabbed that today.
I know they aren't the best things in the world, but this ones been cleaned up and faced so should be all sweet.
haha yeah as far i was aware they were all made to fit stock manifold....
but thats right. will look sexy and lets face it, the stock manifold and piping isnt exactly the nicest thing to look at.
as for the loss in midrange, im sure i wont even notice it. coming from a 20. everything gonna feel torquey as hell haha.
and for a "freddy" manifold it looks pretty good, to be honest.
Lucky I wish mine was raw. Check all your threads aswell before you go bolting it on. Mine had a few dodgy threads which I just ran a tap through. Will be a pain to get to some when its on. And if you have access to one, die grind the water jackets out a bit bigger, to match your gasket, same with your ports. I through my gasket on mine and got a paint pen to mark out the overlap and just ground it out and smoothed it so it matched the ports. Wasnt much to come off but may aswell.
so manifold is on,
bypassed the heater as the core leaks and the oil warmer.
next problem. is that my injectors dont fit my rail because its so badly made that the ports the injectors fit into are different depths ranging from 8.4m to 11.9mm.
so gotta get another rail,
and i have to do somethin about the dowel thats in my crank. for some reason my flywheel doesn't have the hole to accept said dowel..
anyways. no one really reads this crap, so here's some pictures
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
