well friday was a little dissapointing.
ran into a few issues on the dyno.
vct controller was turning on and registered rpm, but it wasnt actually doing anything. next problem was that the tps wasnt getting a signal either. apparently these two problems are linked. the way the 25 has been wired, i apparently missed the part that said i needed to power a wire from the ecu that gives power to the vct solenoid and tps. so i will be fixing that during the week.
next problem and a bigger one is that the bee*r rev limiter isnt letting the engine rev past 6000rpm.
unfortunately they ran outta time to disconnect the bee*r and fix the vct/tps and so the tune has only been partly done, and will require a little touch up once these things have been fixed.
having said that, it made 201.9rwkw on 14.5psi limited to 6krpm.
  • 4 weeks later...
and we have game over....
finally decided to do a compression test on the 25 to see if it would tell me why the cars a pig to start cold, random idles on 5 cylinders (but will rev and drive on 6) and why from time to time itll just blow a massive cloud of blue smoke as i pull up to a set of lights/stop (never does it driving or under boost).
so compression test results returned this
cold
80
80
110
120
80
120
warm
140
120
145
145
100
135
i wasnt to worried till i got to number 5 on the warm test.
put a little oil in the bore to see if itd bring compression up a bit but it still only read 100psi.
so im assuming rings are real happy in general but somethin else. maybe head gasket/head is the cause of the low readings on 2 and especially 5.
  • 1 month later...
have neglected this thread as much as the laurel lately.
after the comp test i got a leak down test done on it.
which confirmed the valves are f**ked in number 5. 75% leak trough the exhaust valves.
ive since sold my statesman and bought an r31 as a daily.
so the money from the statesman is gettin dumped on the laurel.
have bought a recon head for it. and this weekend ill hopefully find the motivation to pull the engine out.
then its time to pull it down. measure up and buy parts.
will be gettin forged pistons and new bearings and as i got the recon head for half the price of havin mine done ill likely slap some pon cams in it also.
Well I just bought a new engine. Picking it up next week.
Recon head. New bearings. Waterpump. Timing belt.
Which means ill have a series 2 rb25 long block for sale with a spare recon head. Paid $600for the head on sunday... found the full motor yesturday. Always the way. Haha
Picking up new engine on thursday night.
Picking up some 850cc denso injectors tonight. And have got a tomei fpr and top feed rail ordered from fleabay.
Gonna run it on e85 this time.
Just need to get manifold gaskets and studs. And then start swinging them spanners again. Eta 2 weeks.
Its goin to be very mildly tuned to start with. Goin from 180rwkw rb20. Ill be more then happy with a measly 220rwkw for now. Need to try and prolong the life of the rb20 box till I can afford an rb25 box and tail shaft
engine came out on thursday night.
stripped down the block friday night.
spent saturday morning fitting the exhaust side to the new block, then attempted to fit my top feed injectors and fuel rail to my inlet manifold.....
....thats where everything went to shit.
the rail doesnt fit. at all.
was going to make up some brackets to make it fit, but then I found a greddy copy front facing plenum on gumtree for $200 so grabbed that today.
I know they aren't the best things in the world, but this ones been cleaned up and faced so should be all sweet.
haha yeah as far i was aware they were all made to fit stock manifold....
but thats right. will look sexy and lets face it, the stock manifold and piping isnt exactly the nicest thing to look at.
as for the loss in midrange, im sure i wont even notice it. coming from a 20. everything gonna feel torquey as hell haha.
and for a "freddy" manifold it looks pretty good, to be honest.
Lucky I wish mine was raw. Check all your threads aswell before you go bolting it on. Mine had a few dodgy threads which I just ran a tap through. Will be a pain to get to some when its on. And if you have access to one, die grind the water jackets out a bit bigger, to match your gasket, same with your ports. I through my gasket on mine and got a paint pen to mark out the overlap and just ground it out and smoothed it so it matched the ports. Wasnt much to come off but may aswell.
so manifold is on,
bypassed the heater as the core leaks and the oil warmer.
next problem. is that my injectors dont fit my rail because its so badly made that the ports the injectors fit into are different depths ranging from 8.4m to 11.9mm.
so gotta get another rail,
and i have to do somethin about the dowel thats in my crank. for some reason my flywheel doesn't have the hole to accept said dowel..
anyways. no one really reads this crap, so here's some pictures
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
