exactly why i want a fixed back. the sr3 recaros i have are amazing seats for street use.
but even on a spirited hills run you could feel them allowing you to slide around a bit. im sure once i have the harnesses in itll be not as bad.
gen nissan sensor by itself is something like $200-$350 check ebay if you like
these are a copy sensor not the cheapest ones I could find but way better than Nissan
the sensor's are used in lots of different models in the US so plenty of company doing cheaper than Gen ones to try
I used one is s14 still going fine now 12 months later
I have 2 left in stock in SA
Edited by 1400r
  • 2 months later...
Well not a lot has happened recently.
Due to getting rear ended back in december and injuring my back.
Bad enough for me to have lost my job for being off work for so long.
I was finally cleared to work on my own car as therapy, so started doing bits and pieces whilst trying to not hurt my back.
Eventually as of saturday just gone I got the engine together and ready to test fire.
Primed the fuel pump, and this is where it went to shit haha.
Literally as soon as I started to prime the pump luke started yelling at me to turn it off.
That's when I noticed my top feed fuel rail has decided that fuel is better off on the outside.
So with that in mind Alan, Luke and myself just tidied up the engine bay a bit, put the bonnet back on and other little bits.
Currently I just need a longer throttle cable and a battery and then technically the engine bay is done.
I will be ordering a GKTECH fan as soon as I'm back at work, as well as the GKTECH abs removal kit.
I decided to swap my pair of recaro reclinable seats and rails for a velo gp90 and cash my way.
with some random mounts and brackets.
I severely regret this decision. But I did want to go to a pair of fixed backs anyway.
It doesn't fit very well with the mounts I was given with it, so I'm going to have to make something up myself it seems.
This is how it currently looks.
  • 2 months later...
Well, some progress.
I've fixed the fuel rail, it no longer leaks.
The velo doesn't fit at all, it's far to wide in the shoulders and hits on the door.
I've sold that to my mate for his silvia, and I'm going to go seat shopping on tuesday.
Probably going to end up with a pair of sparco sprints.
Throttle cable has been swapped out for an s13 one,
still need to swap out the ps pump as it leaks.
and still need to make a battery fit in it.
Need to get a new afm as the standard one is causing issues with the injectors, and I haven't even started the car yet. Haha.
But after the sale of my chaser on friday, I've got a nice cash injection to finish it off.
So assuming I can find some seats and boostworx have some free space It could quite possibly be running by next weekend!
So with the cash from the chaser I went out and bought a pair of Velo GPT-2 seats, they are basically the same as a gp90 except narrower across the shoulders and a little bit deeper bolsters.
Mounted the drivers seat in wednesday night.
Excuse the mess.
Needs to be a little bit lower but I'll sort that out eventually.
Bought a z32 afm tuesday night. Wired that up today.
Finally decided I can't be f**ked finding a battery that'll fit where the standard one is now that there is intercooler piping in the way. So I bought a battery relocation kit.
Started doing the wiring for that this morning. Then I got over it. Engine bay side is done. Will do the rest later today/tomorrow.
Bought a GKTech fan as my rb25 fan hits on the alloy rad, even with f**k loads off the fan cut away. Turns out sr20 fan hubs bolt onto rb water pumps, so no need to run the gktech fan adapter.
Other than that, once I get the battery in it'll be ready to get towed to Boostworx for a tune.
Had alot of issues at the tuner. Many wiring issues popping fuses. Apparently at some point during the first engine swap I must have caught a wire on a sharp bit of metal and it started to rub through.
This caused it to pop ignition fuses as soon as you hit ignition.
all fixed now though and was tuned yesturday.
Turns out it's not a vg30 turbo at all. It's just neo turbo.
Made 214kw. Makes 15psi by 2600rpm ish, got to confirm that once the car gets here so I can read the dyno printout. (currently on a trailer on it's way).
Bleeds off real quickly though. From 5500rpm it starts dropping right the way down to 10psi. So new turbo will be required soon.
VCT still isn't working as I ran out of time to sort it out.
Now I just need to get mounts made for my velos, wheel alignment and rego.
Will be getting a weld in half cage in the near future.
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
