The "EDGE" R33 Skyline GTS25t has been out since 1999 at least, made by ****PIT TATEBAYASHI (GODDAM IT! I've been vBulletined!!)... it's still doing the rounds at the car shows, me and the SAU boys from Sydney saw this one at this years Tokyo Auto Salon. AFAIK, the kit has been copied and is sold in Australia already? Can someone clarify this?
https://www.sau.com.au/forums/topic/37446-edge-bodykit/#findComment-751746
Yeah Rezz, the first time i saw the car in one of the pics you took in your photo thread :rofl: Can you tell me a little bit about C0ckpit Tatebayashi as i can't read japanese on their webpage? I can barely find any info on the car or kit on the web, only on the Official C0ckpit website. Are they popular in Japan? Do they manufacter parts or do they just sell and tune stuff? In the Gts special issue of HPI there is a ecr33 with the kit that was imported.
https://www.sau.com.au/forums/topic/37446-edge-bodykit/#findComment-752374
About C0ckpit Tatebayashi: C0ckpit stores are just your regular "Bob Jane T-Mart" type wheel, tire and tune up place, but Tatebayashi (and others) have complete "turbo tune-up menus", where you can drive your S14 in, and 2 days later, have a 450hp monster on your hands, with a complete set of coil-overs and 18" wheels and tires too. So they do almost the same job as a regular Tuning workshop... I say almost, because the emphasis (and where they make most of their money) is in the wheel and tire business.
I'd go to C0ckpit if I didn't have any contacts with a regular tuning workshop (ie: C-West :rofl:) as they do the complete job in-house, and you can just choose a "tune-up package", you don't have to know what every part does.
About the "EDGE" bodykit: Sorry, my bad, I said before that C0ckpit Tatebayashi produced the "EDGE" bodykit... well they don't. The bodykit is produced by Emotion R, and is quite expensive compared to similar looking front bumpers by BoMex
Heres the EDGE front bumper for 79,000 yen (A$992):
...and the BoMex BM Type II front bumper for 30,500 yen (A$383):
I know which one I'd buy!
So C0ckpit Tatebayashi don't manufacture kits as such, but use other brands. I wouldn't say the EDGE kit is common (hence the price!) but they are made to the highest standards as is usual with the low volume Japanese brands. I guess try and go for a cheap EDGE knock-off, or the BoMex...
https://www.sau.com.au/forums/topic/37446-edge-bodykit/#findComment-752426
Thats pretty exy for just the front bumper! I have thought about going for the Bomex as it is similar, however I like the Edge much better. I dunno why but it appeals to me. There are also many more Bomex's around, which i guess is attributed to it's availability and price and good looks. I'm gonna have to do more searching to find a cheap knock off if one's available.
Thanks Rezz.
https://www.sau.com.au/forums/topic/37446-edge-bodykit/#findComment-752594
edge front bar is nice mmm:)
miz-33t off these forums has it on her car, but it came on it from japan
heres a pic, thanks to franks :)
http://www.pbase.com/image/9278732
ps rezz i tried to contact u via email and pm few weeks ago, but no replies :(
https://www.sau.com.au/forums/topic/37446-edge-bodykit/#findComment-752861
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
