given I can put my hand on mone and almost get a burn off it - yes it is needed and I do agree with teh above statement. heat kills these things - I have a $4500 bill to prove it.
Yeah for sure I support that, they get HOT enough for cooling to be a concern. But what I'm wondering if the oil taking too long to warm up is a concern. My new radiator won't have the "cooler" (warmer) built in, and whether or not that is a concern on the cold mornings I'm not sure.
  • Replies 44
Posted Images
of course they would be too hot to touch, they shed heat into the engine coolant which ranges from 80-110 degrees lol
just plumb one of the pipes next to a radiator pipe (even touching it) and youll get a bit of heat transfer
if this theory works, i'de just be mounting the external cooler so it is physically touching the radiator core. or is this bad?(dont flame me it isnt how mine it lol)
thats how i have mine setup right now. im sure there isnt MUCH heat transfer, ideally youd want the pipework inside the radiator fluid, but this is the best option i had till my new radiator goes in
Looks like B&M SuperCoolers are the go.. http://www.bmracing.com/PRODUCTS/Automatic-Transmission-SuperCoolers
‘LPD’ or Low Pressure Drop feature includes two bypass channels nearest the fittings to allow fluid to flow freely especially when cold to prevent lube system failure.
That's for a 11x7.25x0.75in unit which seems pretty similar in size to what everyone else is running. They have larger units but the fittings are larger too which would be a bit of a pain. If you're in a lot of city traffic they also have the same coolers with fans on them.
Chuckie this is exactly what I want. Can you still pick them up new from Mazda? Or do you need to find a second hand unit?
I was taking to a mate about this exact cooler last night; he reckoned Mazda charges $400 brand new. Supposed to be an incredibly efficient cooler for it's size.
if youre not moving there is probably no point in having a fan on a transmission cooler. once youre moving and you need the cooler to work, well, youre moving!
Unless you are sitting in peak hour traffic in summer.
But if you mount it above the reo, the engine fan will pull air through it anyway :)
I have one of these in my R33 with modded C4 auto.
http://www.onautos.com.au/epages/opa.sf/en_AU/?ObjectPath=/Shops/opa/Products/PW05388
But am now worried it wont be enough so am looking to get a 30 row oil cooler core and use that with a fan. I also have a transbrake and was told to box will see 120+ degrees within a few seconds on the transbrake.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
