Hey all my girlfriends R32 has had 2 motors die in her r32 and now she is deciding to drop a 25 in there so we have a heap of cheap parts that are up for sale, i'll start with a few things i can think of and add to the list as i find more stuff:
First RB20 (130,00K's)
Blown head gasket and exhaust valve, currently dismantled;
Bottom end is not that bad but the exhaust valve landed in the first piston bore and made some gouges in there :(
Head is seemingly fine except the exhaust valve will need replacing... offers on these two!!
Cams in perfect condition $ Offers
Second RB20 (76,000Ks)
Low Compression on 6th ran fine though just lean in the top end :(
Head is perfect (Just Tested) $250
Intake manifold $ Offers
Exhaust manifold (Just replaced with perfectly straight one) $100
Perfect Condition Cams $ Offers
Bottom end needs rebuild $ Offers
Also these Items;
1X RB20 turbo in decent condition $100
1X RB25 turbo in good condition minimal shaft play $250
1X RB25 turbo suit rebuild, held boost fine just a bit smoky every few days $ Offers
2X RB20 ignitor packs $ Offers
5X Rb20 Coils seem fine just installed one in my motor and it runs fine :) $25 Each
9X RB20 Injectors 6 are known to run fine 3 i've never driven with so may need to be tested $ Offers will sell lot or individually
1x RB20 Rocker Covers Painted metallic black $100
1x RB20 Rocker Covers silver oil hose connector is broken on one needs welding $30
1x RB20 Good condition Exedy Heavy Duty Clutch $ Offers
1x RB20 flywheel $80
1x R32 standard rear bar pretty beaten up Silver colour $50
1x pair of Monza front R32 shocks Good condition sit at a nice low height, top adjusting nut of one is damaged $150
If you are chasing any RB20 parts or wiring PM me here and i'll let you know if we have any ;)
Cheers, Tobbie 0418510695
Edited by tobs_r32
https://www.sau.com.au/forums/topic/374464-tons-of-rbr32-stuff-for-sale/
I'm in Hobart area Sven. And yeah tof I only had it running in the car for around 6 or 7 hours and didn't really notice it until my mechanic went to tune it and compression tested it. It's pulled apart at tad engine reco atm
I'm in Hobart area Sven. And yeah tof I only had it running in the car for around 6 or 7 hours and didn't really notice it until my mechanic went to tune it and compression tested it. It's pulled apart at tas engine reco atm
yep cool, do you mind if i ring them about it? , how much are you chasing for it?
not a lot dude, after being buggered around so much myself with dodgy second hand parts i wouldn't do it haha! The head was fine and passed all the tests but mark was saying the bottom end is just worn and needs a pretty decent rebuild. I brought it off a guy on here as a fully working RB20 and only had it in a car for a few weeks. What are your plans for it??
NEW UPDATED LIST;
Intake manifold $SOLD only the top half sold, still have sensors, 2x bottom manifolds etc.
Also these Items;
1X RB25 turbo in good condition minimal shaft play $SOLD
2X RB20 ignitor packs $ SOLD
1x RB20 flywheel $SOLD
1X RB20 ECU - $SOLD
1X Perfect RB20/S1 RB25 AFM - $120
Coil Pack Looms - Sold
1x RB20 Intake pipe $40
4x Rb20 Cam Gears $20 each
1x Standard RB20 Coil Pack cover
1x R32 Reo plate for behind the backseat with bolts $50
Still have more wiring and sensors in good condition if your after any ;)
Cheers, Tobbie
Edited by tobs_r32
  • 4 weeks later...
Sill have most of this stuff and more!! Make me some offers!!!
Also have;
2x CAS - $offers
1X Pioneer CD Player good working condition $30
1X R32 straight pipe from the front pipe back (Decat as well) has all the hangers on it mounts up nice.. sounds ANIMAL!! $50
1x Front pair of ISC N1 coilovers 9 months old (7,000ks) Currently being rebuilt $500
1x Rear pair of bilstein Adjustables good condition $300
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
