hey all looking to sell the GTR, ive owned it for a year and a half with no problems until it recently let go of the number two bearing, i cant be bothered rebuilding so its for sale.
Car needs either a new engine or engine rebuild as the number two bearing has started to go
its a 1993 R32 GTR with 125000k on the clock i bought it from an importer in wangara in march last year with 96000ks on it and drove it too and from work as well as weekend cruising 100000k has obviously been done, by nissan wangara.
paint: white
mods list:
suspension:
unbranded coilovers (have no idea what brand as theres no markings but were on the car when i bought it)
cusco camber arms and strutbraces
performance:
car has three inch exhaust off the dumps with varex cannon muffler (sounds mint)
apexi pod filters
eboost street boost controller dyno tuned for 9psi and 12 psi dyno sheets for proof 300hp at the rear wheels
engine completely stock otherwise
has a brand new exedy heavy duty button clutch less then a thousand ks on it
brakes:
car has dba race pads good once they warm up but squeak when u first start driving
other then that stock GTR calipers and Discs
Exterior:
car has N1 bodykit minus the rear and front lips
is currently sitting on R34 GTR vspec 2 rims with dunlop sport maxx tires with 80% tread left on all
3 out of 4 rims are immaculate not a scratch but the front left has small amount of gutter rash
front bar has paint scraped off on the left side from when i let the missus drive.....
and currently has a dent in the rear left quarter panel from some idiot reversing into me (but will be fixed before sale)
Interior:
interior is excellent no rips in any of the seats only two bubbles in the dash pretty spotless :)
thats all i can remember now lol
Price: price is 10k ono i have full set of R32 gtr rims which i can put back on and lower the price for potential buyers
i have no idea how to upload pics so ill drop a link :D
http://s1224.photobu...7/Confused1991/
Cheers, Chris
Edited by Confused91
https://www.sau.com.au/forums/topic/374487-r32-gtr/
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
