Sucks with the clutch mang. I have had an excedy cushioned button in mine since the swap. No issues whatsoever. Must be a hit and miss dealio. I wanted to organise a night at the drags soon but guess u wont be heading out. an always come watch the rest of us have fun.
  • 3 weeks later...
VL box and custom clutch on its way, got new plates will upload pics soon
and to the guy in the van this morning, sorry im not much of a morning person but yeah i work at Duncan foster (link below) pm me for details on what you want to do to your r32 :)
just read the whole thread. props for doing what many people have talked about and never done. nicely put together engine. If it were me going for power and torque i probably would have made the CR around 11.5:1 and tuned it for E85.. would have been nuts then :D
Yeah need to get in car videos/ bumper videos sometime soon
ok well old gear box is out, clutch plate 4/5 still good,
pressure plate fingers are badly worn,
the thrust bearing (appears to be the culprit) is fairly chewed out on the inner surface that connects to the input shaft. It shows signs of metal rubbing on metal and seizing on the input shaft
Single piece tail shaft & MX7 box next to old bits
Nothing new, still waiting on clutch to turn up
I decided to do some maths
.........RB30/20........MX7/VLT.....Difference with 3.89:1 diff............Difference with 4.11:1 diff (coming soon)
1st.....3.321:1.........3.580:1.........7.3% Increase in acceleration........12.5% Increase in acceleration
2nd....1.901:1.........2.077:1.........8.5% Increase in acceleration........13.8% Increase in acceleration
3rd.....1.308:1.........1.369:1.........4% Increase in acceleration.............9.3% Increase in acceleration
4th.....1.000:1.........1.000:1.........--------------------------------------..............5.3% Increase in acceleration
5th.....0.759:1.........0.759:1.........1% Decrease in aceeleration............4.3% Increase in acceleration
This is a bit misleading because the gear will be over quicker, hence you'll be in the taller gear sooner. If you were to graph the acceleration of both diffs overlapping you'd see on average the acceleration isn't improved greatly when looking at a large spread of kph. In just first gear etc it will be a large increase though.
Yup i was, speak to sams performance, he builds some really high powered LS motors bit expect atleast an 18 month long cue :P
Yeah, the 4.11 diff will only give a 5.3% increase on paper compared to the 3.89, but looks like a bigger increase if you add the vlt ratio and compare it to the standard gears and 3.89 diff
And yeah taller gears = more acceleration and less top speed
but this is all on paper, will chuck it on a dyno afterwards to see what difference the 4.11 made on acceleration
flywheel before being ground
Flywheel after its been ground and ready for balancing
flywheel being spun up to check for balancing
New cushion button clutch plate and modified pressure plate
Blancing Pressure Plate
Spinning up pressure plate
thats all for now
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
