Yeah but they aren't too familiar with rb's, they seem more rotary based.
Is hard to find someone who knows rb's n/a cars and haltechs with out the "that will do" or "that's close enough" attitude
aim is to have it ready well before the all jap day at silverwater on Nov 13 and there is stuff i need to do outside the tune
thought you went to castle hill exhaust
(oh and im trying to find someone close to sea level as possible as you know my car doesnt have an altitude adjuster :P )
next week ill start calling up the tuners that i have in mind, will keep everyone updated
Got a call from Mick first thing this morning, and there may have been a bit of misinterpretation on my part,
mick said that he said; i got to have all these cars ready for a race meet which all these and these i sponsor have to be ready for the long weekend
so my bad in my part there
but yeah he also hadn't realised it had been there for so long and said im right to have the shits but he has promised that nothing else will leave his shop until my car is done
So yeah we'll see how it goes from here
I doubt he reads the forums, and ive also had heaps of time to build joels rb26/30de and make it all 100% like brand new & perfect. But i guess having a whinge gets things moving
though still need to fit the oil cooler, new oil and filter and plugs (after its run in), fit and adjust the new coilovers, fit the catch can, give it a decent wash and go for a pie run and drive to new castle all before 13th of November
Will up load pics, dyno sheet pic and a couple vids tonight (no driving videos, as i was driving)
But f**k me its fun to drive.... light goes green, slight hesitation then at speed limit before i get to change to 2nd, and i haven't tried full throttle yet, more trying to keep it on the speed limit for now :D
No skids i like my licence, (if there were i wouldn't post it :P )
and my phone decibel app says its at 98 decibel at idle... will need to get that checked out
Pictures
RB26/30DE extractors and shiney stuff
RB26/30DE - Painted cam covers to match car with carbon & black and grey carbon fibre timing / valley covers
RB26/30DE - ram tudes, velocity stacks, trumpets, shiney round things, what ever you call them
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
