Ty
I don't think ill hit 8200rpm often will find out next dyno day or when i put it on a track sometime next year
yeah, that'll happen.... lol
im going off other 26/30de builds and so my bet is 165rwkw.
Gotta say you were close, but my boss was slightly closer
Will up load pics, dyno sheet pic and a couple vids tonight (no driving videos, as i was driving)
But f**k me its fun to drive.... light goes green, slight hesitation then at speed limit before i get to change to 2nd, and i haven't tried full throttle yet, more trying to keep it on the speed limit for now :D
No skids i like my licence, (if there were i wouldn't post it :P )
and my phone decibel app says its at 98 decibel at idle... will need to get that checked out
you need to ask your self...
what would jesus do?
Your clearly taking the piss... R31 owners don't have cash to spend on..... Anything.
Awesome build thread was def worth a read. Now once Levi gets his shitbox fixed we can go to the drags. Keen to see u 2 scrap it out lol.
Uleh u can have 6 pod filters now to really confuse the po po.
If you need ideas for ram tube shapes, have a look at stock bmw engines... Late model M3 and M5 tube shapes curve fairly well 90 but open up on the radius. The other idea I had was to change the angle of the intake/throttle plates. I noticed on a few of the big boy jap builds in the late 90's there was a 'wedge' between the tb's and head to angle the tb's up for a better intake angle.
Nice build... well done for having a propper crack at a N/A RB build.
With 4.11/4.3 gears it would be a verry nappy thing on the street.
Cheers
Justin
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
