Awesome, have fun abroad
pictures are loading so while i wait ill type up the brake and suspension report
Test speed: 4km/h
deceleration peak: 63%
Deceleration average: 51%
Hand brake test: 25% left to right
Deceleration peak: 13%
Left to right brake imbalance;
Front: 5%
Rear: 17%
front to rear imbalance;
Front: 71%
rear: 29%
Wheel alignment;
Front: 1mm toe in
rear: 0mm
ride quality;
Front left; 71% - firm
front right: 81% - firm
rear left: 80% - firm
rear right: 74% - firm
left to right shock absorber imbalance;
Front: 12%
Rear: 8%
Weight distribution;
Total weight: 1318kg
Front axle weight: 724kg
rear axle weight: 594kg
front left: 359kg
front right: 365kg
rear left: 285kg
rear right: 309kg
left to right weight imbalance;
Front: 2%
Rear: 8%
Well that's all the information that was given to me from Davids auto who done the brake and suspension report
guess its a good start to know where i am at so i know how to tune it all properly
Oil cooler sandwich plate
Oil cooler lines going into the oil cooler
Oil cooler being stealthy
Catch can
Remember a while ago i mentioned the 2 fittings for the catch can;
And now they are actually being used (ignore the oil patches they did leak a little oil when i pulled the fittings off so i could connect the new lines)
and an engine bay shot... yeah i know needs a clean
as I'm not the greatest with photography, hopefully someone has taken some decent pictures at the all jap day and posted it on other forums and shit, or even recorded me giving it a decent squirt over the bridge, now to troll the other forums for pics :P
(plus im too cheap to buy a decent camera for now)
Nothing new yet,
Got some holidays that are coming up in early Jan, might visit a track or something try and get some vids
But I got some more pics from the All Jap Day...
https://www.facebook...RIncPhotography
http://www.nissansil...=0#entry6450906
http://www.facebook....192043784209148 (ha and mines the album cover)
http://forum.jdmstyl...apan-Day-Sydney
yeah I know aye, wish I had that camera skill, I'm like "yup its all in frame" *click* "done"
on other news, slight update.... Excedy HD Ceramic clutch is dying, again. First one lasted 3 weeks - it was an "extreme" HD Cussion button clutch.... enough said, this lasted a month and a half till it started having issues
*symptoms, I have to go into 2nd before putting it into first while stationary, 1st 2nd and 3rd hard to get into gear. on down gearing 3rd and 2nd crunch as they go in, on a small rev then launch it will slip for a couple seconds, if not then it will take off and half way through the gear it will start to slip then pick up again.
*Other issues caused by me, I rode the clutch a little on take offs in the first couple weeks till I got used to the torque, clutch point and what revs I could and shouldn't launch at for different driving styles (yes I can grandma it now), I also have a habbit of riding the clutch for about half a second in wet wether to keep traction
local mechanic near work, gravity bled the clutch, then took it for a drive, he said he is surprised that its died so quickly as he's used them in in more powerful turbo'd cars, though I did mention the lack of turbo gives me instant response and torque, he also said that me riding the clutch for the first couple weeks would have done some damage but not the amount it has this quickly
anyways looking into a new ceramic spring button kit, and might get the pressure plate modified
while I'm at it I may as well do the r33 rb25det gear box up grade
fingers crossed this clutch can last a couple more months
oh and I'm going to make up some engine braces as I couldnt find any that were long enough to go from the bolts around #1 cylinder to the strut towers,
Greg, you MUST get those headers ceramic coated, the blue makes it look gross!!!!
oh and your number plate is crooked
yes I am being pedantic because there is nothing else on the car to pick on :nyaanyaa:
except that it has 2 too many doors :whistling:
sucks to hear about the clutch issues, thought about a different brand? I <3 my jap clutches, better than anything else I have used in any car over the years.
and another vote for full noise track videos!!
K B Clutch Engineering
143 Coreen Ave, Penrith, NSW 2750
Outer West Sydney, Western Sydney p: 02 47321692
Speak to Keith, he's the man. takes a new exedy 5puc, rebuilds it with cabonic pads and heavier presure plate (mine is 3800lb).
mine, delivered to canberra was $366, and i havent had an issue behind my 315kw/650nm rb30 track car...
i wouldn’t do the 25 box in yours either, theres no need unless you have no mechanical sympathy at all.
those headers arent perminate, maybe titanium or chrome dipped on the tuned length extractors when i get them made up, plus they have faded
the holes on the bumper are inline, the holes on the number plate are crooked, :P but new plates coming soon
if it was a 2 door i probably would have chucked an oversized snail shell on the exhaust :P (way too much room there)
i thought exedey were a decent brand, though gotta say, a N/A that has killed 2 clutches, i must be doing something right
but yeah as long as this once lasts long enough, I'll stop being a tight ass 31 owner and buy a 25 box, carbon fibre tail shaft, and a decent/ top of the line clutch kit suited for this.... yay researching again... oh and gear sets for the 25 boxes are over priced
track videos after working clutch, crunching gears probably not going to be too impressive
grumblebee - yeah was thinking of getting another new pressure plate and getting it strengthened, though your track car is a dedicated track car, alot of clutch plates built for track die on the road, but will look into clutch plates to suit. Oh and its a series 1 r31 sillo gearbox, bought it for $50 and was told its a non syncro gearbox by the owner
pete - cheap.... that was the extreme one lasted 3 weeks after the cruise last jan :P wouldnt you or jen need the clutch after skidz?
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
