I've got C's, It is very good, solid works well and is very easy to fit. As far as I know Nismo make two one of them shortens by only 10% the other I Don't know, quality should not be a problem though
OK i've been doing some research and it looks like there are basically two types of shifters:
- Short Shifters (aka solid, direct)
- Quick Shifters
What's the difference?
From the pics I can see of the two, the short shifters just shorten the stick, while the quick shift kits come with a shortened stick and also a whole lot of other nuts, washers and brackets etc (i'm not very good at technical stuff:D).
If any would care to explain I'd appreciate it. Thanks!
Summary so far: C's is the way to go
I got my C's from takakaira.com in Japan delivered to my door took 2 weeks cost $A634 via credit card.
The proper short shift changes the length of the stroke at the bottom of the gearleverwhich actually makes the change faster and also has the effect of shortening the length of the arc your hand moves through when you change gear. Just shortening the top of the lever shortens the arc but doesen't change anything at the bottom.
Currently I'm thinkinf of shortening the top of my C's .............Has anyone else tried this. It should give a really short shift but might make it a bit too stiff.
| Hype ^ | yes that's the idea would make for a double shoetening of the arc your hand moves through. Was also thinking of fitting a gate in the top of the console instead of the leather boot like in some Ferraries.
A short shifter is simply that, the distance between the pivot point and the gearknob is shorter.
A quick shifter has the pivot point changed so the throw required to change gears is less as well as the stick being shorter, however it also means it is stiffer, or firmer to change. Most people prefer this and the difference is usually not that great. Imagine a see-saw with the hinge moved to one side. Same principle. Just think, all those physic's lessons are paying off :)
If you have ever been in an excel with a really short gear stick, it usually means that is has had the top hacked off with a cheap fake momo glue back on top. If you have even driven a car like this you know that it makes changing gear really ****. Only spend money on a quick-shifter kit if you really need it. I mean the skyline shifters aren't too bad in the first place.
The C's shifters use adapters to change the pivot point, another way of getting a shorter shifter is to remove the ball joint from the shifter and have it reattached futher along the stick.
Anyway never complaint about the length of the Nissan shifter until you have driven old school 4wds. Most seem to have about 2.5metres of throw.:D
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
