i put my 25/30 together on the weekend with a genuine nissan rb30et head gasket and ARP studs for a rb25det head. i did a cold compression test after i had set the timing yesturday and i only got 30psi. the head is rebuilt and the bottom end came from a running motor. the studs were torqued up to 88nm as per the rb30 service manual.
all i can think of is that the nuts on the arp studs are wound all the way down and that the gasket isnt sealing properly.
or is 30psi normal for a cold test?
cheers
Edited by the_jack
https://www.sau.com.au/forums/topic/374518-compression-test/
when i put the head studs in i wound them all the way in then backed them off a turn but then when i put the nuts on they went all the way to the bottom and bound up so i wound all the studs all the way in.
Are you guessing that the pressure is seaping out across the thread of the stud? I want to keep eye on progress here, I feel I could learn something.
If it was me, I would have suspected timing could be off. You could do a leak down test before you take the head back off and see where you hear the PSSSH from. Even if timing is off one degree, you will get almost no pressure at all.
What I would do is a leak down test on the first cylinder(I'm guessing you are getting 30psi read across the board), listen to the air psssh. If its coming from the exhaust or air filter, your timing could be off or something more. If you take out the plugs from the other cylinders and can hear air coming out of the next piston, you know the gasket isn't sealing. Also what you can do if you do decide a leak down test, get some rubber hose and run it around the head gasket around cylinder one and listen if you can hear the air pssshing from where the studs are. If you can you know the issue.
Also after quick searches etc, the arp stud kit looks only to come with one set of washers...
Edited by SargeRX8
leak down and figure out where its coming from. i'd also get another set of washers anyway, you really dont want the nut on the end of the thread. not that it'd give you low compression but you should use 25 torque figures for the head bolts/studs not 30e(t)
Don't pull it apart. Pinpoint the source first. You'll ruin the head gasket as its been crimped already. You've also over torqued them a little(I don't think it should impact it that much though...) so you want to be careful the bolt isn't weakened by fiddling with it too many times. Its MUCH MUCH easier to do a leak down then it is to rip the head off.
Yeh Mafia is right about the torque for those studs. ARP states 80ft/lbs which is about 108nm. You have under torqued them if you did it to 88nm.
If its the head, sometimes when they cut the seats, they dont seal properly until the engine is run for a while and then they come good. Unless ofcourse the valves were lapped in before assembly.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
