i put my 25/30 together on the weekend with a genuine nissan rb30et head gasket and ARP studs for a rb25det head. i did a cold compression test after i had set the timing yesturday and i only got 30psi. the head is rebuilt and the bottom end came from a running motor. the studs were torqued up to 88nm as per the rb30 service manual.
all i can think of is that the nuts on the arp studs are wound all the way down and that the gasket isnt sealing properly.
or is 30psi normal for a cold test?
cheers
Edited by the_jack
https://www.sau.com.au/forums/topic/374518-compression-test/
when i put the head studs in i wound them all the way in then backed them off a turn but then when i put the nuts on they went all the way to the bottom and bound up so i wound all the studs all the way in.
Are you guessing that the pressure is seaping out across the thread of the stud? I want to keep eye on progress here, I feel I could learn something.
If it was me, I would have suspected timing could be off. You could do a leak down test before you take the head back off and see where you hear the PSSSH from. Even if timing is off one degree, you will get almost no pressure at all.
What I would do is a leak down test on the first cylinder(I'm guessing you are getting 30psi read across the board), listen to the air psssh. If its coming from the exhaust or air filter, your timing could be off or something more. If you take out the plugs from the other cylinders and can hear air coming out of the next piston, you know the gasket isn't sealing. Also what you can do if you do decide a leak down test, get some rubber hose and run it around the head gasket around cylinder one and listen if you can hear the air pssshing from where the studs are. If you can you know the issue.
Also after quick searches etc, the arp stud kit looks only to come with one set of washers...
Edited by SargeRX8
leak down and figure out where its coming from. i'd also get another set of washers anyway, you really dont want the nut on the end of the thread. not that it'd give you low compression but you should use 25 torque figures for the head bolts/studs not 30e(t)
Don't pull it apart. Pinpoint the source first. You'll ruin the head gasket as its been crimped already. You've also over torqued them a little(I don't think it should impact it that much though...) so you want to be careful the bolt isn't weakened by fiddling with it too many times. Its MUCH MUCH easier to do a leak down then it is to rip the head off.
Yeh Mafia is right about the torque for those studs. ARP states 80ft/lbs which is about 108nm. You have under torqued them if you did it to 88nm.
If its the head, sometimes when they cut the seats, they dont seal properly until the engine is run for a while and then they come good. Unless ofcourse the valves were lapped in before assembly.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
