want to know how to adjust s2 tps as i have been told it is different to adjusting s1 tps
mine has the 2 plug tps with 2 harness connectors plugged in but mine is manual :/
could someone please give some detailed post everything about adjusting and the steps please
i know this but need to know if i am correct
top plug
1 volts should be 5v
2 is signal
3 is ground
bottom plug does not matter too me cause my car is manual or does it ???? should i go get another tps with just the one plug?
ok now with multimeter check that your getting 5v supply?
probe the back of harness connector wires 2 been (+) & wires 3 been (-) & check & adjust to 0.45v-0.50v ?
then check with them in same position that you get somewhere close to 4.00v on WOT with ignition in on position?
then do u reset ecu like u have to for old ones?
if somebody could just clear all this up for me would be greatly appreciated
and also just 1 more thing is it true that you can adjust base timing on s2 without a consult to put it into base timing mode?
cause yer i been told that you cant or does the old trick of unplugging the tps work if it does do i just unplugg the top plug? (the only 1 i should have plugged in if its manaul)
or can u trip the consult connector thing into thinking its in base timing mode someone please help me with this?
RBJ37
https://www.sau.com.au/forums/topic/374524-rb25det-s2-tps-clarity/
Adjusting is the same as a series 1, just twist the sensor left to right.
Pin 1 is the power for the TPS
Pin 2 is the TPS opening signal
Pin 3 is the earth
You can check the sensor by reading the resistance of pin 2 and 3, With the accelerator not pressed it should be 0.4V, with it pressed fully it should be 5.0V and half depressed around 2~3V, IF you measure the resistance between pin 1 and pin 2 thats for the TPS SWITCH. Because the sensor is a 2-1 setup. It should have 0 resistance not pressed and then increase when you press it.
The test you said above sounds like reading voltage of the harness which is just probing the 1st terminal and earth it on anything, it should be 5V.
You can check other parts of the harness but you need a diagram of the ECU so you know which terminals to probe etc etc
Also if you unplug any sensor the car just puts itself into a fault mode and will idle at 1500rpm flat.
Yer that's what I sed check 5v supply witch is pin 1 and earth
And so I was right mine sed.
At the TPS on harness side pin 2 and 3 shouldnt it be O.45v to O.50v not 0.40v like you say and isn't it 4.1v at WOT not 5.Ov ?????
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
