hi guys currently getting my motor built at moment it will be ready to get tunes soon when its back in and i was wondering cause im new to wa where is the best place to get it tuned a reputable place ?
its a r32 gtr by the way
please pm me
thanks guys
  • Replies 55
hi there, best place in town is allstars in malaga, they do a good tune and get plenty of good feed back. im getn my r33 gts done there in the next few weeks.
Big question is who built the engine ? Whenever tuning a new engine there is alot of reluctance, cause when something goes wrong, as is often the case, the tuner doesn't want to get blamed for a poorly built engine, and vice versa.
Also, what ECU have you got, turbs etc ?
Please post results in the SAUWA Member area :thumbsup:
If the bad boy works, I'll be telling every one don't u worry,
Quick parts list
Bottom end built by me with
Nissan bearing
Spool rods
CP pistons 86.5
Nitto pump
Trust sump extension
Head consists of
Tomie -
Pro cams 270x10.8
Type B springs and retainer
Bronze valve
Ferrea +1mm valves
Tomie gaskets
1.2 HG
1000cc xpurts
GT 35 .82 vband
3.5" dump
6 boost and 48mm pro gate with screamer
040 intake and 2x 044 externals all direct wired
3lt surge tank
3lt baffled catch can with rear head drain,
Think I covered everything and all issues RB related
Let's hope it all works
  • 5 weeks later...
MOTOR BUILD UPDATE, ALL BUILT AND FINISHED GOING BACK IN CAR NOW !!! maybee some things i missed out !!
sard 700 cc injectors
brand new garret 2860-5 turbos with all new gaskets
hks exhaust gasket and tomei metal intake gaskets/throttle bodies
acl race series full engine bearing kit, along with king bearings unknown what they were for !
shim head gaskit race series (metal)
N1 water pump
tomei UMEDA oil pump
tomei 260 deg cams
custom built extended sump and pickup with trap door setup in sump (MADE BY RED R RACING )
rebuilt front diff and preload reset
engine balance
machine crankshaft
ross harmonic balencer
cp forged pistons, 30thou over size from original bore
eagle conrods
gates performace timing kit
replace crankshaft oil galleries with screw in plugs
deck block
recon head ,full set of valve guides,3 angle valve cut ,set of shim tappets to cams supplied
aftermarket valve springs
custom work (drill and weld up oil galleries in head advised by red r racing)
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
ARP Mains + Head Studs
All New Hoses And Gaskets
Oil Relocation Kit + Cooler
alloy Radiator
new clutch built by (JIM BERRY RACE CLUTCHES QLD)
Nismo Airflow Meters
New O2 Sensors
trust 600x300x120mm Intercooler,
recent full rebuild on gearbox
running the nistune ecu with nismo afms
and a blitz i colour elect boost controller
will be interesting to see how much power i will make ,would anyone know an estimate on power figure ?
Thanks I bought these brand new turbs cause I blew one up originally when I had same turbs before not expecting motor to go and make a new stronger motor with more power so yeah I hope I can make some good power anyways was hoping for 600 but oh well ...
A mate with an RB28 running 26psi and e85 with big cams and a shit load of head work made 630rwhp, so with your setup on pump98, and similar boost I'd expect around 550rwhp thumbsup.gif
Make 500 easy, pending ignition and boost will indicate how far you want to go. Camshafts could be alittle bigger for some extra hp, I changed from 260's to 272's and noticed a mega difference top end. Either way, great street and all round setup.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
