  • Replies 55
I use Xspeed, Ant is one of the best tuners around.
pitty he doesnt give a f**k about average joe customer....
hyperdrive know what they're doing, just hope you dont get booked in on a really busy day.
I must admit I had this impression of xspeed and actually went and spoke to them and ended up canceling my hyperdrive booking and going with them as they could do what I wanted quicker and for cheaper, except my cooler piping blew off down the free way, but who new xspeed did road side assist, this was a few years ago,
I chose asg for there recent reputation and closeness and vipec tuning,
Yep if you not spending 30k + they don't seem interested... they won't touch haltech either.
Edit: Was referring to XSpeed
Alot of places won't touch Haltech, maybe that is more to do with the ECU rather than the workshop.
nearly every person i talk to has something bad to say about x-speed which is why ive never gone there.
Haltech and Nistune are about the best serviced ECUs in Australia now.
Some shops have a short list of ECUs they know and wont use anything else.
^^ this is 100% BS maybe Australia but not WESTERN australia. there are only 2 places that will even touch a Haltech ecu and that is C-RED and Cypher.
edit: actually i have heard of one other place in Kenwick but it was so random and un-heard of i cant even remember the name
also the last time my mate got his haltech tuned by c-red it was pinging its tits off so much he took it to cypher and the bloke at cypher, he drives it in with 400ish rwhp 25det, gt35r .63 800cc sards, 044, 6boost 50mm tial etc and the guy says the max power it can make is was either 360 or 370 on 20lbs!? haltech + WA = FAIL
Edited by Char
Haltech, Tuned by T&R Green, Topracing, Performance Unlimited, Garage101, Cred, Intune, RPW, Cypher, Rotormotion, GTI and a few Others.
I find current Haltechs easy to tune but the old versions have poor software.
where were you 6months ago when me and my mate where driving to about 10 garages to get his car tuned! :P none of them could even recommend anyone -except Mick at ovaboost said try cypher
+1 for hyperdrive.
Andrew definitely a great tuner. one of the first in perth to start doing nistunes i think
and does not do half ass tunes if they are busy... - that is complete bullshit.
Edited by colt75
i hate to start a shit fight but unless you work there full time and have done for years theres no way you could know exactly how every one of his tunes has gone. sure hes a good tuner but the last time i was there i left pretty dissapointed with his efforts, was very unproffesional.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
