Hi guys, just thought I would post up some info about my mods and current power level, for those interested in what power levels we can expect out of the VQ35, for what mods.
Back when I bought the V35 2 years ago she made 151rwkw, stock, 5AT.
Since then I have done a few 'engine' related mods including:
Kinetix intake plenum
Ground Wires
Kinetix High flow cats
Megan Racing Y-Pipe
Custom 3" mid pipe
Cheap Chinese rear muffler
CF Intake pipe
HKS panel filter
Oil Catch can
Fitted an SAFCII but NOT tuned yet - ECU is completely untuned.
So at the SAU:SA dyno day last weekend she made 175rwkw - the SAME dyno as the 151rwkw.
Note that this is a Mainline dyno - not a 'Disney' dyno like most - so power levels are much lower than other dynos around the country. For your reference an individual with an RB25 R32 had made 205rwkw on a Dyno Dymanics dyno recently, then made 155rwkw at Willalls. Admittedly he seemed to be running less boost, but other people got up to 25% lower than what they had previously dynod on other dynos around town too, and it is a common occurrence.
Anyways, that is my story so far. Enjoy the dyno graph.
And you can see my dyno run at the 6:55 mark of this video :
Also, in the video make sure you check out 5:22 - it is RH9 - the Willall Racing original - it used to make 680awkw, but is now detuned and has smaller turbos to run on the track. Still sounds angry!
https://www.sau.com.au/forums/topic/374530-dynod-my-v35-at-the-sausa-dyno-day/
Thanks. Yeah I am hoping for another 10 or so when it is tuned. Sadly they were only using 1 wideband probe on the dyno day, and during my dyno run it became dislodged, so I have nfi what my afrs are like. I assume she is running a bit rich, as per normal factory ECUs. I am also getting a resonator fitted this week, as with the HFCs and new 3" mid pipe, it is very raspy. I am assured these will not kill any power, but just take the edge off the raspy sound, and mellow her out.
Yeah turned out that Gavin's Red R35 had had a computer tune-up the week before and Martin Donnon had inadvertently left the car in valet mode. It is tuned there and has made about 340rwkw every single time it has been dyno'd before. For reference a Series 3 R35GTR with the same mods as Gavin's (mid-pipe and Cobb tune) made 361rwkw on the same dyno the other week.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
