RB25 Gearbox with short shifter low k's $1300 firm
Bonnet hinges $50
Drivers side door complete white $125
Dashboard $75
Rear seats $50
Air flow meter pionk label type no plug $100
17" wheels $500 with nearly new tyres and locknuts included
Rear subframe $200
CV shafts $75 each
Torsen diff $150 with side flanges
Rear brake set up $350
Side rear quarter windows $100 each
Rear wiper motor $40
Front wiper motor $50
Power steering rack $150 including tie rod ends in good condition.
All seats belts $50 per corner
ABS unit $50
Roof lining no marks really clean $40
May also have other little parts but not much more left.
Located in Windsor NSW but can post small items at your cost.
All reasonable offers considered.
Tim
0404321205
Pics upon request, text me and ill text you a photo back.
https://www.sau.com.au/forums/topic/374537-left-over-r34-parts/
I have been told it is a torsen out of an S15 and i have no problem with opening it up at all, text me and ill open it up and text you back with a pic.
Tim
Do you KNOW that it's a Torsen diff? If it is, I would like it. If you don't know for absolute sure, I would appreciate it if you would open it up and look/take photos of the centre.
cheers
Edited by Wilkins026
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
