I will be assembling the engine (under the watchful eye of my dad!). The place doing the machining and balancing has recommended King, I was originally thinking ACL.
Seeing as 2 very experienced people on here have recommended one and the other I guess they must be pretty even!
Another quick question, seeing as Nissan builds the engines with graded bearings why do people not have issues when using non Nissan standard size bearings? Or are the differences between journal measurements on the crank tiny (and if so why do Nissan bother with grades bearings?)
Hmm, what a conundrum. Now you'll have to start a thread on who's opinion is the best opinion. My advice would be to ask your engine builder, if you are the engine builder, then it won't matter
There is a whole thread on this only a few weeks back. Explains everything
As long as your clearances are ok and you are using a tri-metal bearing you will be fine. The bearing is not going to be a point of failure and if you were going to be pushing the limits of either manufacturer then building it yourself is probably not the best option.
Even the bi-metal bearings are ok in things mildly tuned - Nissan had no trouble with them
that is the propper way of doing it. and besides, if its got oil they wont ware out. its only if there is an oiling problem it wont matter what is in there.
i personaly have found the tollerances with SOME acl race series bearings to vary as much as 1/2 thou.
NDC is a very good brand aswell.
:thumbsup:
From memory NDC make the factory Nissan bearing don't they?
And yeah, have sent a few sets of ACL back myself but only because we didn't like more than 0.0001 variation.
i line hone then fit bearings to each journal then measure it. we then grind / linish crank to get exact clearances on each journal.
We have found that linishing the crankshaft to achieve an exact measurement will actually do more harm than good. Of course you can generally always take off 0.0001 without too much trouble but anything more than that will make the journal not round any longer and create a wave effect over it. Sometimes it is better to have that small variation in clearance rather than the wavey journal, but once again 0.0001 is generally considered ok for a linish if you absolutely had to.
in over 50 done that way weve never had an issue so i will keep doing the same thing :P
Whatever works for you. I wasn't telling you to change, I was only providing an educational viewpoint for the readers of this thread. Most good engineers can do 0.0001-0.0002 without too much of a problem but go 3 tenths or 4 and the journal WILL become out of round and uneven across the face. Whether that equals engine failure or not, I'm not sure, as there are so many different reasons an engine can fail but I do know that an out of round journal is worse than 1 tenth in clearance
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
