For some reason the idling on my car will just randomly drop wacko.gif even after adjusting it so it cant go any lower and will even stall while pulling up too traffic lightsdown.gif was wondering if anyone had some idea as too what it could be
cheers Gilly
https://www.sau.com.au/forums/topic/374564-idling-trouble/
AFM aswell man. When you're pulling up to lights or something try coasting in neutral, and if the revs drop right down and does the stalling thing then it would probably be a dirty afm. Voltage drops out and no load on the motor lets it die. If that's the case, the car will be really jerky and backfirey sometimes. Don't boost it! Detonation is not cool!!
https://www.sau.com.au/forums/topic/374564-idling-trouble/#findComment-5974976
+1 to the AAC valve and the AFM clean. Regarding the random stalling, my pervious R33 sometimes would do that when I stopped at lights etc. Cleaning the AAC value fixed that. I would also suggest resetting your ECU after you clean both the AAC valve and AFM. You can do that by disconnecting your battery and pressing the brake pedal a few times.
In regards to the adjusting the idle speed, I believe the best way to set it is to connect via a consult cable and use some software (free or paid) to lock the car into what is called "base idle mode" when the car is hot then adjust the screw on the AAC valve. I think you can lock the car into this mode without a consult cable however I can’t remember how to do it. This way you can set the idle correctly as the AAC valve (as well as other systems) are taken out of the loop. This is what I do when I set my idle on the GTST and GTR. Using this method I find my idle speed to be perfect.
https://www.sau.com.au/forums/topic/374564-idling-trouble/#findComment-5975501
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
