For some reason the idling on my car will just randomly drop wacko.gif even after adjusting it so it cant go any lower and will even stall while pulling up too traffic lightsdown.gif was wondering if anyone had some idea as too what it could be
cheers Gilly
https://www.sau.com.au/forums/topic/374564-idling-trouble/
AFM aswell man. When you're pulling up to lights or something try coasting in neutral, and if the revs drop right down and does the stalling thing then it would probably be a dirty afm. Voltage drops out and no load on the motor lets it die. If that's the case, the car will be really jerky and backfirey sometimes. Don't boost it! Detonation is not cool!!
https://www.sau.com.au/forums/topic/374564-idling-trouble/#findComment-5974976
+1 to the AAC valve and the AFM clean. Regarding the random stalling, my pervious R33 sometimes would do that when I stopped at lights etc. Cleaning the AAC value fixed that. I would also suggest resetting your ECU after you clean both the AAC valve and AFM. You can do that by disconnecting your battery and pressing the brake pedal a few times.
In regards to the adjusting the idle speed, I believe the best way to set it is to connect via a consult cable and use some software (free or paid) to lock the car into what is called "base idle mode" when the car is hot then adjust the screw on the AAC valve. I think you can lock the car into this mode without a consult cable however I can’t remember how to do it. This way you can set the idle correctly as the AAC valve (as well as other systems) are taken out of the loop. This is what I do when I set my idle on the GTST and GTR. Using this method I find my idle speed to be perfect.
https://www.sau.com.au/forums/topic/374564-idling-trouble/#findComment-5975501
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
