Most recent cars have a clear coat from the factory; are you talking about "Flow Coating"?
i.e.; Rubbing back the factory clear and then Respraying the clear so it can be wet sanded and buffed for a better than factory gloss?
A claybar by itself will not increase the gloss of your paint; it is designed to remove contaminants bonded to the paint, so you can further refine the paint by correction.
It is a step within a process.
https://www.sau.com.au/forums/topic/374571-clear-coat/#findComment-5975793
Flow coating would be what i am after.
Is it worth it? And what would i be looking at in terms of pricing?
You'd be best to talk to a few spray painters, find out what their opinion is, and whether they'll actually do it.
Depending on the standard of your paint and the straightness of the underlying bodywork; it could be the difference between average and amazing.
I would hazard a guess at over a grand to easily 3 grand. If you want perfection; you'll pay for it.:thumbsup:
https://www.sau.com.au/forums/topic/374571-clear-coat/#findComment-5977231
Manny where are you from? what makes you assume you will need a flow coat and the car is just not covered in shine robbing swirls? have a look at my site www.immaculatereflections.com.au and see some of the cars I have done. I reckong with out seeing the car a good detail is all you would need.
this also means, car gone for ALOT less time, doesnt come back with buffer trails on it from the panel beater "buffing" it, its protected and cofferected properly with the best equipment and methods, and not many painters like "flow coating" its kind of like asking a detailer to "tidy up my engine bay" only if you get what I am saying so they take less pride in it.
Regards,
Mitch
https://www.sau.com.au/forums/topic/374571-clear-coat/#findComment-5978186
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
