My CD player has jammed, and I also need a band extender for my radio. I've been told I should just replace the stereo system. However, I want the console to remain looking the same. I am unfamiliar with putting new sound systems in a car, and I figure they are all different shapes and sizes, and that my centre console will need to be cut to make it fit, and thus losing the buttons it currently has. Can someone explain to me how it works, or post pictures of your aftermarket stereo so I can see how one would look?
Quick shot of mine when it was in Japan post-52513-0-51869100-1313743839_thumb.jpg
You will need one of these http://www.ebay.com....=item2eb73e308e
This was just a quick search on ebay.. you can search elsewhere. :thumbsup:
Get the genuine nissan parts if you can, those aftermarket ones aren't much chop. I got one from the states for my V35 and it was around $400 or something like that delivered.
I must be using the wrong plcae in japan to get mine. the controller is worth more than that.
Yeh im not sure chris i paid around $350 i think for mine when i got it, it was from an infiniti dealer in the states that has an E Bay store link is below to his store he has a few of the AC controllers up for 150 + postage USD
http://myworld.ebay.com.au/grubbsperformance/&_trksid=p3984.m1439.l2754
I got it from an Infinti dealer on ebay. Riverside if memory serves me correctly.
Edited by omp
I had already fitted a pair of Alpine amps in place of the std amp, and some decent speakers, which improved the overall sound,
i then picked up a top range Alpine head unit for a very good price, so rather than try and bodge up a single din into the factory
Bose slot,
So i decided to move the DVD/nav unit by elongating the wiring loom, as i wanted to keep the use of the factory screen
for my reversing camera and TV, and fit the HU there, a bit of a mission, but the result is neat and works very well, with far better sound quality as a result.
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
