Getting the handsfree Bluetooth is something you'll have to experiment with once you get to the Bluetooth section, as I've had to when I've setup the phones I've owned. My memory isn't too good at that last stage. I suggest you remove the navigation DVD from the drive in the glovebox first which will temporarily disable a bunch of menus.
This procedure will only be relevant to the later Nav system that have a Carwings button, not the earlier one that didn't have this (2004 and some 2005 Stageas). Remember, the bottom right button is the "back" key,
First press the second button along on the top row (the one next to the TV button) Choose menu item 4/6 Next choose menu item 8/8 This takes you to the Bluetooth menu.
Turn Bluetooth on (top menu option)
Go to the second to last or the last menu option and it's there from memory that you tell the Stagea to search for your phone which must have Bluetooth turned on and searching for a Bluetooth host to connect to. When your phone finds the Bluetooth device named "My-Car" you then enter the PIN 1234 into your phone. Once paired, your phone should connect automatically every time you turn the ignition on in your car and the phone should also show it's paired.
You may have a problem (as I did initially and another forum member did) of your phone hanging up just after you answer a call using the steering wheel answer button. Hopefully you won't but if you do, one of the other settings (not sure which) on one of the other menus in the Bluetooth section could need it's status changing. Apparently there is an option which if its' enabled, will divert calls to elsewhere. I can't remember what I did but it took trial and error. Keep track of everything you change here as you may need to go back a step. It's frustrating not having the menus in English, but at this stage we just have to do our best. It works beautifully however, and did so with my old iphone 2G, my LG Optimus P500 and now my Samsung Galaxy SII.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-5976184
Thank you so much man...
Worked perfect. We dont have the Steering Wheel controls unfortunately so we won't have to worry about that issue.
Is there anything else you can do with the Bluetooth. For example stream your music to the car stereo? I'm doubting it, but worth a shot lol.
Thanks again. Really appreciate it.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-5976428
Glad to hear it was helpful. Was it the bottom menu item you used to pair the phone to the car? (The one that states a bunch of stuff in Japanese then the numbers 1234?)
I'm not sure if you can do anything else with it. I doubt it though as the bluetooth handsfree system mutes the stereo system, and audio seems to be sent through a single speaker that could be hidden under the dash. I haven't had a chance to investigate yet as it's my wife's daily driver so I don't get to drive it much.
If you don't have the steering wheel buttons, I'm not sure how you'd answer calls unless you do so at the phone itself.
There's a heap of other menu items in there that mean nothing to me. You can connect an auxiliary source (video and or audio) to the aux in socket located on the tuner module located behind the passengers side panel in the boot and then select AUX in from the TV section of the Navigation screen. You'll need to run a cable all the way back from the boot to the dash, and it'll only work with NTSC video signals (not PAL). There's lots of info in here relating to adding third party TV tuners. You're lucky in Aussie as you have a few choices. Our digital TV system is a little more unique and I haven't seen any compatible 12V gear around yet.
Some have connected ipods and iphones for video/audio. More info here and on Youtube.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-5976973
  • 2 months later...
Hi Spong
I tried on my 04 Stagea, (it has carwings, but only when you select it from pushing the menu (4th) button on top row), and I only get 4 options once in the carwings column. The only other column visible is the one for the trip computer info; fuel consumption, timers service reminder & fm radio adjustment.
Though in saying that I was trying it on the weekend and somehow got to a menu which had a picture of a phone, and it seemed to be searching, but I didnt have my phone nearby so when I tried it again with phone in the car, I couldnt find it, and it appears I deleted a heap of entries in the process. Something with channel numbers and things with envelopes (like emails). Doh!!
I'm beginning to think I dont have actual 'bluetooth' as I have the phone cable in the centre console, and I also have the steering wheel buttons, "vol, up/down, a pic of a phone, a pic of a person speaking (voice menu?), and the track/station up/down button." I also tried by voice command saying many things like "commando risto, setup, pair phone, menu" to name a few, all to no avail.
Obviously my navi controls are still in Japanese.
1 thing you dont mention is if the ignition switch has to be on accessory or the ignition position when pairing the phone? What did you do if you can recall?
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6076728
  • 7 months later...
The Japanese to English translation is available for the M35 S1, but the the S2 is still being worked on. This has all been coordinated by the great people in this forum. There's also a NZ contact/installer for this.
See: http://xanavi.com.au/Xanavi/Xanavi_Language.html
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6384124
Hey Spong,
Quick question. Does it work without the DVD nav cd being in the reader? I tried the process quickly, but couldn't get anything to work from the 2nd button on the top row. I don't have the DVD as unfortunately it wasn't with the car when I got it. My car has a "carwings" menu, so I guess it is one of the ones that works.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6384188
No you don't need the Nav DVD, and I recommend you remove it as it "greys out" lots of unnecessary menus, hence making it easier to setup bluetooth handsfree. I've left our Nav DVD out since a week after we got the Stag, and it hasn't prevented bluetooth, fuel economy or service interval reports from working just fine.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6384266
I tried this yesterday but couldn't remember the menus to select :blush:
Would love to try it again and get Bluetooth working but my screen will not turn back on!
Has anyone had an issue where their screen just turned off and wouldn't turn back on no matter which buttons you pressed?
Also, anyone got a tip for keeping the screen up? Mine keeps trying to hide itself and needs to have the button pressed to over ride the automatic close three times to keep it open.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6406071
Pics or :ban:
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6406237
  • 7 months later...
I found out how to stop the screen turning off - in the same menu that you adjust brightness of the screen there is an "ON/OFF" setting at the very top. This seems to be a "auto time out" screen function as once I turned it off the screen never did it again.
I have managed to pair my phone to the BT (iPhone 4S) - follow Spong's method above but I found I could only find the Bluetooth on my phone when I had the first Bluetooth menu opened, rather than the last.
So my process was:
Info button (Next to TV) -> 4/8 -> 8/8 (Bluetooth) -> First menu item -> Go to phone's Bluetooth pairing and choose My-Car / 1234.
However, the Bluetooth seems pretty lousy quality, I'm not sure where the mic is, but it's got some wild frequencies transmitting to the other person and what I hear isn't great either. My Pioneer headunit in my previous car was far superior.
The steering wheel buttons work though, not sure I could get them working with a headunit.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6725140
I managed to stuff mine up so that the screen turns off after a short time, and can't work out how to reverse this. Can you tell me how to get to the screen where brightness and the time out option is? Thanks.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6725250
Glad it worked out. I have to find the setting now that is forcing a redirection, as everytime I answer a call it drops out within 2 seconds, but works fine when I make the call.
I'll post a solution once I find it if anyone else is finding the same thing.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6728510
Yeah, mine had that problem when I first set it up. Can't remember which setting it was except that it was in the Bluetooth section and I just used trial and error until I found it. I'd really like to pair my PM35 to more than one phone if possible, but haven't figured that one out yet. I've photographed the screens in that area and hope to get a translation from a friend sometime in the next few weeks.
https://www.sau.com.au/forums/topic/374619-pm35-bluetooth/#findComment-6728667
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
