hey,
was wondering how to tell if i have a mechanical 2way diff buy looking at the diff center...
when i turn the wheels back and forth they both spin, but this also happens on my stock diff.
how do i tell if i take the diff housing off?
cheers
In the stock diff there's a cartridge right in the middle of the centre, between the internal gears. That's the viscous cartridge and is not there on mechanical diffs.
Now, if you look into a mechanical diff, you will see the end of a pin sitting in a pair of ramps. Look at the images in here http://www.google.com.au/search?tbm=isch&hl=en&source=hp&biw=1582&bih=863&q=2+way+diff+ramp&gbv=2&oq=2+way+diff+ramp&aq=f&aqi=&aql=&gs_sm=e&gs_upl=1228l8730l0l9276l24l21l2l8l8l0l262l1695l3.2.5l11l0
and see what I mean. 2 way has even ramps (same both sides. 1.5 way and 1 way are biased (ie, steeper ramp on one side than the other.)
That's not a Nissan VLSD centre. See attached imaged for Nissan viscous centre. Red arrow points to side gear visible through notch in end of centre case. Green arrow points to 1 of the spider gears visible through hole in case. Yellow arrow points to viscous unit hiding right in middle of diff centre.
Edited by GTSBoy
Don't despair. Looking at your attached image it's a little hard to see and be sure. Look at this pic of a Cusco 2 way. http://j-trade.cranky.jp/IMG_P6287.JPG . You can clearly see the two ramps on each side of that central spindle. This one is perhaps harder to see, but you can see that the casing is different (with a hole in it more like yours). http://t1.gstatic.com/images?q=tbn:ANd9GcQVRWL705gCzkuwyZJ5j3R29ase1wHOYGbRm_xq3JUwfqRf9zJGsw
See if you can move your diff centre around a bit to see your ramps more clearly.
Also, have a look at this thread http://www.skylinesaustralia.com/forums/topic/170563-gtr-skyline-differential-types-helical-mechanical-viscous-etc/ and see what other images of LSDs you can google up to see if you can recognise the maker of your diff. As I said, I'm no expert, so I don't recognise it.
cheers
I think it might be a stock GTR diff (which are 2 way). the diff ratio on it is 4.111:1, get some better pics. it's impossible to tell what it is as we can only see part of the ramps.
yeah, ok that casing is completely different. definitely aftermarket of some kind then. jsut look at pics of casings till you find one with those little bands on it. that should at least identify the brand, then you just need to get a good look at the traction ramps to find out of it's 1 way/1.5way/2way etc.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
