Had a little bad luck and need money.
So I don't think i can afford to keep this...
I drive this daily from Noarlunga to Port adelaide, and doesn't miss a beat!
Toyota Cressida mx83 grande.
full jzx81 front cut conversion, engine. gearbox, dash, pedals etc etc
114xxx on engine/gearbox/dash
32 gtst rims
Digital dash (from chaser)
lowered king springs all round
Timing belt replaced at 106xxx kms
LSD (recently rebuild)
Near new HD clutch
Garret boost gauge
No abs
De-badged
Rear muffler removed
Momo steering wheel
Walbro 500hp fuel pump
Has a front lip
Leather interior (very comfortable, decent condition)
Climate control
All electrics work (windows, seats, mirrors etc)
Plenty of rego left!
Only things is gearbox is noisy(common problem, shifts perfect though)
drivers door has a dent(car park accident) but its only damaged to the one door so just need to find a replacement door
seen for $100, don't have time to replace as i work 6-7days a week.
other then that, VERY reliable and very fast car, and will not get any unwanted cop attention
With exhaust, bigger front mount and 16psi, should get 230rwkw
Probably a few other things I've forgotten
$7499
Give me a call/text on 0433 596 509
Will consider swaps for cheaper car and cash my way
NO COMMODORES!
Only post a comment if interested in car, otherwise don't waste my time
If i don't get what i want ill keep it and pay $20 a week off my bills lol
https://www.sau.com.au/forums/topic/374634-1jz-manual-mx83-cressida/
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
