Hey guys, have just joined the forums as I am in the market to pick up an R32 GTS-T. I noticed a few on the forums for sale, but also found myself clicking back through months of posts and finding some that *were* for sale, but no real indication of if they have sold or not. If you're selling an R32, preferably in black, then I would love to know about it.
EDIT: Sorry should mention I'm in Sydney.
Edited by cherring
https://www.sau.com.au/forums/topic/374638-wtb-r32-gts-t/
Thanks heaps to the guys that got back to, I did pick up an R32 though, so now am looking for body parts, a GTR front bar and Rear wing before I go get it resprayed. Gonna be a lot of fun.
https://www.sau.com.au/forums/topic/374638-wtb-r32-gts-t/#findComment-5977442
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
