hey guys i am looking for a z32 afm now i am just wondering  do i get a tt awf or a n/a afm
oh and i have a r32 gtst if that makes a dif
I don't know what awf is, but N/A and TT Z32 AFMs are identical - p/n 22680-30P00, red sticker
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5976548
ahh ok and ill get the part number and check it that way
it isnt brand new its 2nd hand
Why risk it with a 2nd hand AFM? It simply is a waste of money.
But a new one, from a respected workshop - you won't get a fake, or one that could break in 6 months.
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5977421
Might want to read this first under the z32 wright up about z32 afm:
http://www.garage7.com.au/
They look the same until you cut them open.
i had a look at this site good info there use have convinced me to get one of these lol
now the mission to put it on
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5977592
Don't know what all the fret is over second hand genuine units are... Most of these are run with good filters. What if someone bought a brand new unit for their car, used it for 6 months, and then upgrades to map and sells the afm for half the price? Its a good saving on a unit which hasn't much age and will probably last you the life of the car...
I bought my genuine piece over from the US a while back. Never had any issues with it(touch wood). I wouldn't buy an "z32 alternative". Often, the fake ones are listed as alternatives or aftermarket parts.
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5977625
How do you know someone only used it for 6 months?
You don't.
AFM's are so cheap that it's just not worth the risk. They seem to only last 10yrs anyway so almost a consumable like a timing belt really. They certainly don't last the life of the car at all. AFM's are known to fail regularly.
A 2nd hand Z32 could be 5 years old for all you know, and belted around a bit. For the sake of a couple $$, just get a new one.
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5977753
Exactly anyone can say part x has done 10000km, but in reality it has probally done close to 100000km. That's the problem with buying second hand parts. Seeing as the afm is a critical part of keeping everything running sweet i don't see why people don't fork out the extra say $100 for a new one. I got my bosch one bran new for $310 from bursons.
https://www.sau.com.au/forums/topic/374647-z32-afm/#findComment-5977838
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
