  • Replies 59
NismoR34 ... thanks for that mate ... yeah but this dealer told me he won't let me have it checked by the RACV ( see this thread for further info: click here ) so it made me a bit unsure as to whether I really wanted to check it out ... so .... I am still looking :)
I have one for sale.1999 er34 skyline coupe
white,manual,approx 25000kms.was bought from japan with 9000kms.
mods full bomex kit,carbon fibre bonnet,bilstein coil overs all round,apexi pod,hks 4 inch titanium exhaust,blitz bov,os giken twin plate clutch.
made 231RWKW with pfc and bleed valve.cross drilled rotors,race brake pads.rego rwc hardly driven as keep loosing licence.
Will make it stock for cheaper price will take 35k as modded.see my gallery for pics
Why Ed? so we can have two white skylines together? :(
Rigo has one already down here (white one) but he's a bit rich for me right now. As for Prestige's one, I can't buy it as I am financing a portion of the car's value on a lease, and my lease company doesn't go for cars that are not in Australia. So ... :D ... I gotta stick to the ones locally (either private or dealer) ... * which , makes it harder *
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
